Bad 2008 KOP Gyro - Need Replacement
All,
We (Team 1619 - Up-A-Creek Robotics) have a bad 2008 Gyro. Our 2006 Gryo is working, but our 2008 Gyro was intermittent until today, when it stopped working altogether - I'm guessing that we have a bad solder joint on one of the balls. Does anyone have a 2008 Gyro that they are not using and would be willing to sell to us? Thank you, Kevin Taberski Mentor - Team 1619 |
Re: Bad 2008 KOP Gyro - Need Replacement
Have you tried to fix it?
Getting creative with a hairdryer might fix your poorly soldered ball. |
I'm tempted to bake it in the oven actually, but I need to get a better handle on the time/temperature for the solder that was likely used.
It's unlikely that a hair dryer is hot enough - at least I hope not! Kevin |
| KOP Gyro Lag | FRC4ME | Programming | 13 | 16-02-2008 20:22 |
| Bad Gyro??? | Joohoo | Electrical | 3 | 22-01-2008 11:50 |
| Some 2007 KOP Gyro Performance Data | yoyodyne | Control System | 3 | 02-04-2007 20:07 |
| KOP Gyro seems to run-on after turn stops | PhilBot | Control System | 8 | 05-03-2007 12:43 |
| KOP Gyro | John Gutmann | Programming | 12 | 12-12-2005 21:59 |
