Go to Post it is actually more important to understand and be able to clearly state the question than it is to know the answers. - GeeTwo [more]
Unread 16-02-2008, 22:42
taberski taberski is offline
FRC #1619 (Up-a-Creek)
taberski is an unknown quantity at this point
Bad 2008 KOP Gyro - Need Replacement
All,
We (Team 1619 - Up-A-Creek Robotics) have a bad 2008 Gyro. Our 2006 Gryo is working, but our 2008 Gyro was intermittent until today, when it stopped working altogether - I'm guessing that we have a bad solder joint on one of the balls.
Does anyone have a 2008 Gyro that they are not using and would be willing to sell to us?
Thank you,
Kevin Taberski
Mentor - Team 1619
Unread 16-02-2008, 23:23
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Bad 2008 KOP Gyro - Need Replacement
Have you tried to fix it?
Getting creative with a hairdryer might fix your poorly soldered ball.
Unread 17-02-2008, 05:37
I'm tempted to bake it in the oven actually, but I need to get a better handle on the time/temperature for the solder that was likely used.
It's unlikely that a hair dryer is hot enough - at least I hope not!
Kevin
KOP Gyro Lag FRC4ME Programming 13 16-02-2008 20:22
Bad Gyro??? Joohoo Electrical 3 22-01-2008 11:50
Some 2007 KOP Gyro Performance Data yoyodyne Control System 3 02-04-2007 20:07
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
KOP Gyro John Gutmann Programming 12 12-12-2005 21:59
