Go to Post I want to win, but I want to beat my opponent when they are at their best. - wilsonmw04 [more]
Unread 17-02-2008, 00:29
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
CIM Pinion issues in Toughbox
Today we were driving around testing our manipulator when a loud screeching noise came from the chassis. We checked everything out, and found that one motor on one side was very hot compared to the rest. We took the gearbox off of that side (we are using 2 CIMS in each of the Toughboxes, with one stage of gear reduction removed). When we disassembled the transmission, we found that the key in one of the pinions was sticking out at an odd angle and the pinion could rotate on its shaft (hence the screeching). The pinions were mounted as shown in the Toughbox assembly guide.
Upon further inspection, we deduced that the key slipped out from the between the teeth of the retaining ring, allowing it to remove itself from the keyway on the shaft and the pinion. Our solution to this problem was to cut the key so it is flush with the pinion and place a 1/4" washer at the end of the pinion before installing the retaining ring.
If you are using the Toughbox or any other gearbox that has the pinions mounted in a similar fashion, I strongly urge you to inspect your transmissions to ensure this won't be a problem.
Unread 17-02-2008, 01:07
dtengineering's Avatar
AKA: Jason Brett
Re: CIM Pinion issues in Toughbox
Thank you for posting this. In fact, thank you to 1726 for posting your results of various tests and efforts this season, I'm sure you have inspired several teams to try new things as a result.
However unless I misunderstand your description of the problem, I get the sense that this may be a real fluke, rather than an inherent flaw in the gearbox... I'm not saying it didn't happen... obviously it did, however teams have been using similar methods of attaching the pinion and key for years without any problems. So, just to make sure I understand...
Referring to the tough box user manual http://lib.store.yahoo.net/lib/yhst-...erGuide1-1.pdf you had part number 18 (the 2mm x 2mm x 14mm key) slip out past item 20 (the 5/16" clip)?
When I rough out an estimate of the spacing between the "teeth" of the clip, it seems they should be about 1.6mm apart where they contact the CIM shaft.
Theory says this shouldn't happen... practice and observation says it did. (At least if I understand this correctly.) Perhaps it was something specific to your team's modification of the gearbox, or how the retaining clip was installed?
Jason
Unread 17-02-2008, 01:26
GUI GUI is offline
AKA: Gary
This could very well be something specific to our setup. I'm not entirely sure if the keys we used were the ones that came in the kit (we have a bag lying around with about ten each of pinions, keys, and retaining clips), the key we used may have been longer. Aside from that, everything is set up the same. Our modifications didn't change anything on the first stage of gearing, so I'm fairly certain it had nothing to do with that.
This is definitely not an inherent flaw in the gearbox (I am very impressed by the simplicity and reliability of the Toughboxes), and I was very surprised that it happened.
Unread 17-02-2008, 01:32
AKA: Jason Brett
That makes sense... if the key was longer then the clip could have been pushed down over it, thus allowing it to sneak out as you drove.
The fix you have posted sounds pretty much foolproof, though, and fortunately it happened at a time when you had time to investigate and repair.
About our only "discovery" so far has been that unless the compressor is very well supported and restrained, that those little rubber vibration dampers shear off quite easily in a high-speed impact with a cement wall.... even with bumpers on.
Okay... after SEVERAL high-speed impacts with a cement wall.
Jason
Unread 17-02-2008, 09:05
catsylve catsylve is offline
FRC #3538
catsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond reputecatsylve has a reputation beyond repute
We likewise had a small problem with the key slipping out of one of our motors in the toughbox. Fortunately it didn't cause too much of a problem at the time and the robot just starting going in circles when one side stopped working. We put a couple of spacers in and it solved the problem. The key just seemed a little bit short. We have had no problems since and the spacers worked great. Other than that, we have really liked the setup.
2012 Woodie Flowers Finalist, St. Louis Regional
Unread 17-02-2008, 09:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The key and clip were installed just as shown in the picture in the Toughbox User's Guide, shown here.
This is probably a rare problem, but it is something to keep in mind if either you have the transmissions apart to work on something else (it's a relatively quick and easy mod to shorten the key and install the washers) or if you encounter weird driving behavior or noise. With a single CIM per side, you'll have the robot driving in circles, with dual CIMS you'll get one hot motor and one cold motor and drifting or erratic driving.
Unread 17-02-2008, 11:02
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
We noticed the key being short and had the possibility to come out. After the key and gear were on, we used a center punch to make a dent in the key way preventing the key from coming out.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 17-02-2008, 11:44
AKA: Jason Brett
Well... looking at that picture, then, and hearing another report of this having happened, this may well be a design issue that AndyMark may wish to address in future toughbox/gearbox designs. Like you say, it is easy to fix... when you have the motors out.
Fortunately the biggest design advantage of the toughbox over previous KOP gearboxes is how easily the motors come out. In most cases teams can pull their motor without pulling the gearbox.
We'll keep our eyes open for this... we may even be able to check it out through the lexan panel.
Jason
Unread 17-02-2008, 13:11
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
We had the same problem, with the keyways being to small to work and that they would fall out. Infact we had the same thing happening during our testing, thus, we need to open up the toughbox and rebuild the gear box, which promply fell on the floor and was covered with hair and metal shavings....
Also the CIM came lose and needed to be reattached.
Is now an engineer thanks to FIRST.
Unread 17-02-2008, 15:53
XXShadowXX's Avatar
They call me Cody.
Well guess what, the bot did break down when we tested it and i need to rebuild it, and your keyway trick worked thnxs.
Toughbox broken Evert Kit & Additional Hardware 5 05-02-2008 23:43
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
