Go to Post But frankincense and myrrh will come in handy after your team starts to smell during that first design meeting. - Jessica Boucher [more]
Unread 17-02-2008, 01:43
MrHero MrHero is offline
Engineer/Mentor
FRC #0930 (Mukwonago BEARs)
MrHero has a spectacular aura aboutMrHero has a spectacular aura about
Radio breaks in autonomous mode??
We discovered tonight that when we activate autonomous mode, the radio communication stops working! We are using a competition port dongle with pins 5/8 shorted, and the OI indicates that we are in autonomous mode, but both radios drop into standby mode!
The radio works fine in tele mode, and the tether works in autonomous mode (not exactly practical)..
Has anyone experienced this or have any thoughts?
Thanks!!
Jeff - Team 930
Unread 17-02-2008, 01:44
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: Radio breaks in autonomous mode??
Does it do the same thing with the default code loaded?
Unread 17-02-2008, 01:50
PrincessJae's Avatar
PrincessJae PrincessJae is offline
FRC #2543 (Titan-Bot)
Team Role: Electrical
PrincessJae is infamous around these partsPrincessJae is infamous around these partsPrincessJae is infamous around these partsPrincessJae is infamous around these parts
Send a message via AIM to PrincessJae
Do you happen to be with other teams? I dunno... today we had radio probelms cause when our teams met together to practice we were all on the same channel...
are you sure your not using the switch that disables the RC?
Unread 17-02-2008, 01:55
Engineer/Mentor
No, we had no other robots nearby, and we confirmed that the disable pin (pin 6) wasn't shorted to ground on the competition port.
Haven't tried default code yet (will try tomorrow), but I would expect that from a code perspective, tether mode should behave the same as tele mode??
Unread 17-02-2008, 01:57
GRS GRS is offline
FRC #1764
A tether cable acts as a radio modem with wires, nothing changes from a code point of view.
Autonomous Mode fallen751 Programming 14 09-02-2007 00:28
Autonomous Mode Slick Programming 22 01-02-2007 19:26
autonomous mode seanl Programming 6 31-01-2007 15:59
Autonomous Mode tysonwormus Rumor Mill 11 08-01-2004 22:59
Autonomous mode AntmanIV General Forum 1 17-02-2003 13:30
