Go to Post Really, flight? That is going to feed the rumor mill... - Munchskull [more]
Unread 16-02-2008, 11:18
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
pic: XBot #488 2008 Robot
Unread 16-02-2008, 11:20
run the trap!!!
Team Role: Human Player
Re: pic: XBot #488 2008 Robot
I like the spool you made for your pneumatics. Was that an off-the-shelf-item or did you make it? It will definitely help prevent things from tangling when the elevator is raised.
Nice work.
-Philip J. Fry
Unread 16-02-2008, 11:28
clydefrog88's Avatar
clydefrog88 clydefrog88 is online now
FRC #4087 (Falcon Robotics)
clydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the rough
Where do you mount your battery? We toyed with the idea of having our lift tilted back similar to yours but found that an opposite mounted battery was an effective counterbalance. I really like the simple, effective solutions in your design. Hopefully i'll get to see it in person at nationals.
Unread 16-02-2008, 12:11
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
Nice work.
The spool we made in house. We were hesitant to put anything active on the fork since the path between the cable pulleys and the elevator is very very small but one of the other mentors came up with this light weight alternative to the traditional retail spring-coiled pneumatic reel. And it weighs almost nothing
The battery is in the back under the winch. You can see the location here:
http://www.chiefdelphi.com/media/photos/29748
The CG of the machine is incredibly low. Even with the ball all the way at the top it is very difficult for us to tip over.
The whole superstructure detaches by removing 4 pins and disconnecting the wires so we can work on the chassis separate from our actuators.
Thanks!
Unread 17-02-2008, 02:18
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Nice work.
The spool is probably one of the coolest features of our robot. We hadn't intended to use pneumatics at all -- but testing late last week revealed that our first manipulator design wasn't going to cut it. So, quickly, we brainstormed and designed the manipulator shown here and decided to actuate it with a single piston. We didn't want to have any loose wiring or tubing near our pulleys and lift cables, so one of our mentors -- a senior researcher at Microsoft Research -- devised this mechanism in about 30 minutes. It works great and we're really happy with it. It's too bad it will get hidden behind our protective side panels.
Tilting the lift back also helps mitigate some of the uneven loading on the bearing surfaces caused by the cantilevered load of the manipulator and ball. Our center of gravity is very low and very close to the center of the robot and we might've been able to get away with a completely vertical lift; but we're very happy with what we have. Bringing the ball back above the robot was one of highest design priorities and as result, we're able to travel around the track at full speed while carry a ball at full height.
Stop by our pit in Atlanta and take a look. We're still here working on the last few details, but we're proud of what we've accomplished so far. Hopefully, the season will just get better and better.
--Madison--
...down at the Ozdust!
Unread 17-02-2008, 02:20
iTHOS=awesome iTHOS=awesome is offline
FRC #1258
iTHOS=awesome is an unknown quantity at this point
Send a message via MSN to iTHOS=awesome
Saw you guys today, nice job with getting the ball off the top an back up. (Team 1258 with the fully pneumatics arm was us).
Unread 17-02-2008, 02:34
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Oh my god, why are your omniwheels so small (I'm guessing 3 inches there??? maybe 3.5" at most?)
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 17-02-2008, 02:40
Madison's Avatar
FRC #0488 (Xbot)
You all were the only other folks we saw hurdle, so good job on that. I was a little bit scared with how fast and uncontrolled some of the machines were, so we decided to come back to the lab and test more on our slightly more flimsy overpass.
They're 4" diameter, custom-built wheels to complement the 4" IFI traction wheels.
--Madison--
Unread 17-02-2008, 02:47
rachal's Avatar
multipurpose tool
AKA: Rachel
Oh, okay, nice. The electronics board and spool look pretty too. (Well, everything does, of course.)
Unread 17-02-2008, 04:28
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
Very nice robot. I like the slanted elevator, that's an interesting design and it looks very strong. Do you have a picture of the far side of the pneumatics reel? I'd be curious to see how it's attached such that the reel can spin without twisting the tube leading out of it.
I assume the stomp rocket in the background will be one of those "little odds and ends" soon to be attached – it's the backup system for ball launching in case the elevator's too slow, right?
Unread 17-02-2008, 12:07
dtengineering's Avatar
AKA: Jason Brett
Looks great! See you in Portland and Seattle!
Jason
Unread 17-02-2008, 13:15
Madison's Avatar
FRC #0488 (Xbot)
--Madison--
Unread 17-02-2008, 13:16
Madison's Avatar
FRC #0488 (Xbot)
I don't have a picture of the spool handy, but I'll take or find one today. We've got a brass tee fitting set up so that one part is coaxial with the spool and that allows the tubing feeding air into it to rotate. It's neat.
The stomp rocket actually belongs to the building, not the team. It's a nice distraction sometimes and we don't even need to go outside to play.
Jason
You too! I am looking forward to seeing your launcher.
--Madison--
pic: 173 2008 Robot Jeff Rodriguez Extra Discussion 17 14-02-2008 15:10
488 XBot PNW Statistical analysis, and results from friday matches Fred Sayre Regional Competitions 15 16-03-2007 22:02
pic: Team 488 XBot updated electronics view 1 Fred Sayre Extra Discussion 8 04-02-2007 17:25
pic: Team 488 XBot two lifts getting closer Fred Sayre Extra Discussion 8 04-02-2007 16:58
pic: FRC 488 - XBot - Hex Madison Robot Showcase 5 21-02-2006 19:30
