Go to Post FIRST is not about building a robot, it's about the experience of it all... - Beth Sweet [more]
Unread 16-02-2008, 22:24
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Suffield Shakedown observations...
Hi everyone!
Just got home from Suffield in what was a fun day of action. First off, I want to send out congrats to the Gael Hawks, Uberbots, and Litchbots for winning the scrimmage. Also congrats to Gael Force, BOP, and Panther Project for comming in second.
Here are some observations of the day. I invite those who attended to add on to this report so that we can get the word out there of what to expect.
-Speed = Good...the laps those little speedy robots made did make quite a difference.
-Hurdling = More Gooder!...By the end, it was easy to figure out that the best hurdlers were the teams running away with the competition. The Gael Hawks were amazing, the Uberbots were excelent, and Gael Force was strong as well. All three in the finals.
-Penalties, Penalties, Penalties...This was huge. A great number of matches were decided by penalties.
-The biggest culprit of the day was the "wrong way infraction" which teams would pass over a line, then slightly go back over the line. Keep in mind, once your robot completely passes the line you CANNOT let any part of your robot pass back over that line in the clockwise direction. I'd say there were about 20-30 infractions today on that penalty.
-Hitting outside the bumper zone was pretty evident. You cannot use your arm to hit a robot outside of the bumper zone...they are cracking down on this in a major way.
-Interferance Penalties were also called a bit. More often resulting from a team hitting another team that was trying to hurdle. A couple of times it was called for not allowing a team to pass.
-80" rule...its very easy to break this rule even if you think your robot is in spec! If you fall down, hit your E stop IMMEDIATELY! If your tower is extended, and you dont hit your e-stop, you get penalized!
-Eliminations...these were alot like the quaifiers. One problem I already see developing which worries me, is the fact that you cant really strategize to beat out a stronger team. Pulling off a "controlled defense" is not an easy task...because of this, its hard for the better robot not to win.
-Traffic Jams...suprisingly, these were not as plentiful as I expected. Occasionally there were points where things would jam up going around a turn. The biggest culprit of a jam up was a dead or tipped robot.
-Laps...I did see quite a few teams make a living out of doing laps. The enforcers, spontanious combustion, and Apple-Pi were incredible because they were so fast, yet so well controlled. They couldn't fully offset the hurdlers, but they definately made a big difference.
-Scoring...scoring system was amazing. Flat out.
-Reffing...referees have alot to cover, they have the toughest job this year for sure.
-Excitment...game had its good points and its bad points. I am still waiting til the end to hold out judgement, but I think its going to be a big hit to some people, and a big miss to others.
Once again, thanks for the great time today everyone. We'll see you in a couple of weeks!
Unread 16-02-2008, 23:27
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
Re: Suffield Shakedown observations...
A few notes after watching 5+ hours of Overdrive...
-Scoring Display...even when viewed on a large screen projector, the numbers do not show up clearly. FIRST should englarge the entire scoring panel so the number of hurdles and pushunders are very clear. The lines counter should also not dissapear the instant teleoperated begins, as this important stat is crucial for scouting.
-Tipping over...to all top heavy bots: if you can add weight on the bottom to cancle out your giant heavy arms, do it. Once a bot tips, play becomes uninteresting and akin to merging lanes on the highway.
-Catapults...while Suffield did not have as diverse of a selection of bot styles as i hoped, the catapult style proved itself to be very advantageous if done right. Arm bots need to almost latch onto the Overpass to hurdle, and merely getting close to the OP is not as easy as it seems. The catapults ability to launch while far away makes them lethal.
-Hybrid...if you have no idea how to do it, ask another team to help you program a dead reckon linecrossing code. Some teams just stood in place for the 15 seconds instead of collecting the easiest 4 points in the game. Just remember the value of 1 line now instead of 8 later.
I'm still not impressed with the game, but I'm waiting until Hartford is over to render my judgement.
RPI '12
Unread 17-02-2008, 01:56
Best Available Data
FRC #1778 (Chill Out!)
I didn't get to watch the webcast (kinda had our own robot to build ), but I've got some questions.
Who was the head ref? How much difference did laps make? What was the average score? How many laps did teams who exclusive chased after laps get? How many hurdles did teams get one average. Who got the most hurdles? How many did they get? Did teams try to hide the other alliances balls in the corner? How did the robocoaches work? How was Hybrid mode in general? Did teams go for placement at the end of the match? Where balls typically knocked off the overpass? How many? Did anyone ever get the wrong ball in autonomous? Did robots on the same alliance collide in autonomous mode, resulting in less lines crossed? Inquiring minds wish to know!
Also, I know Litchfield has won this scrimmage before, and didn't the Gael Hawks do pretty well last year? I remember watching their ramps deploy at any rate.
Heh. Wow, that's a lot of questions.
Unread 17-02-2008, 08:34
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Yeah, the gaelhawks were with us, and we almost won.
*Head ref was some guy in an orange suit
*The laps turned out to make a huge difference, and there were some matches that were decided by them (if there were numerous penalties...)
*average score was in the 30-50 range for an exciting match, 0 being the lowest and 76 being the highest
*5-8 laps
*1-2 hurdles (0 low, 4 high)
*We got the most hurdles at 4
*one team tried, but it was their own ball, so i guess it was just a gripping problem. Those balls don't stay in one place for very long
*robocoaches were useful with human input, but not with full control of the robot
*lots of teams took advantage of (attempting to) knock the balls off, and making laps, or combining the two
*many teams did, few succeeded consistently
*teams attempted to knock them off placed balls, but since they were placed with <10 secs left, you needed a quick method to be effective
*not that i know of
*not often... the only real error i saw was that some teams would run into the side of the divider, and would have their automode ruined. Not enough teams actually moved in hybrid to make this judgment.
that answer you?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 17-02-2008, 08:47
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
I was surprised at the number of FRC teams in attendance who also had their sister FTC teams competing in the auditorium a few feet away, who didn't bother to support them.
Gracious Professionalism?
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 17-02-2008, 08:48
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
I was surprised how hard it was to knock the ball off the overpass. Just hitting was not enough.
I agree that the lap bots made a huge difference.
Unread 17-02-2008, 09:00
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
The Head Ref was Dr. Aidan Browne, Head of ALL referees and member of the GDC.
I know it wasn't asked but, FIRST was well represented in Suffield as this was the first time the field had been used in a competition setting. It was a "Suffield Shakedown" for FIRST as well as the teams. FRC Director Bill Miller, FRC Engineering Director Neil Rosenburg, the incomparable FSM from NJ, Paul Kloberg, FIRST National Advisor Dr. Flowers (and Mrs. Flowers, nice to see you again.) I am sure there are others that made the trip from Manchchester, NH that I missed.
All of your questions regarding the game are important, but just keep in mind, this game, even though it seems simple, has quite a few of different variations and will evolve as the events unfold. Week 1 regionals will be very different than Week 6 Regionals and this is only the beginning.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 17-02-2008, 09:17
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
The most-hurdled match was the final match, where the winning team managed 5 hurdles combined (or at least according to the announcer).
The specialized lap-running bots (don't have their #s, the webcast quality wasn't good enough to read them) typically got about 7 laps. That's pretty good considering it isn't entirely likely that an opposing robot will get the 2 hurdles needed to offset that. Even the uberbots above said they averaged 2 hurdles in a match.
The field reset time was not fantastic, but that may have been because the teams were slow getting their robots on-field.
I cannot believe so many teams didn't go for the drive-straight autonomous mode. This is the first year I've been in FIRST where you can actually get some permanent points simply for driving straight. If you have 3 robots that can do nothing else, having all 3 of them drive across the first line is 1.5 hurdles of points. DO IT. This is certainly something I see teams helping with at a competition pre-match: "hey do you have a drive-straight autonomous mode?" "no?" "ok here you go".
If you're having trouble with the code, here's some:
pwmLeft = pwmRight = 127;
if(time < AMOUNT_OF_TIME_TO_DRIVE) // experimentally determined, but 100 might be a good bet
  pwmLeft = pwmRight = 190;
time++;
The farthest autonomous mode I saw was one of the Gaels with 3 quadrants crossed, AND a trackball unmounted.
Unread 17-02-2008, 10:33
AcesPease AcesPease is offline
Teacher Mentor
AKA: Bill Pease
FRC #2836 (Team Beta)
AcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud ofAcesPease has much to be proud of
Don't panic. Some years no one has autonomous ready for the scrimmage events. Many teams were just finishing the mechanical assembly of their bots and have not had time to install and test their autonomous programs. Look for a lot more motion during match one of the first week Regionals.
Bill Pease FIRST Team 2836 Team Beta
Formerly FIRST Team 176 Aces High
WFF 2010
Unread 17-02-2008, 11:01
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Billy pretty much answered the rest of them, so I'll just answer this one.
We worked with the Gaelhawks last year, which is why I remember this so distinctly.
Last year we (the ÜberBots/Gaelhakws alliance) made it to the finals, but lost and came in second overall at the scrimmage. We faced against the Gaelhawks at the Regional and beat them. We were psyched to work with them again at the scrimmage this year, and we finally won together!
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 17-02-2008, 16:43
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Great job to all the teams who showed up. It was a pleasure competeing with and against so many great teams. I was impressed with the speed and efficiency that the Uberbots had with the telescoping Arm. We seemed to be a good alliance along with the trusty Litchbots lapbot to aid in the scoring.
Those of us who are able to attend this scrimmage have a great advantage because we get to test our robots in the heat of the battle while there is still time to fix/adjust things. If you are in the area and havent been there before, mark your caladers for next year because the information you walk awy from there with is invaluable. (Bit you have to signup early next year, as there is only room for 30 teams and I understand there was a wait list)
Thanks to all those volunteers who help put this together. I run the webcast with some other mentors on the team and we are there when the countless number of people setting up and somthimes are there till the wee hours in the morning finishing setup before hand. Its come a long way since it began as a makeshift testing ground for a hand full of UTC teams and now its as large as many regionals (and more in the wings waiting)
So a big thankyou to all those that have helped it grow over the past several years. The fact that FIRST sends down a full staff and leadership team, along with the Field and scoring systems in addition to many officials that work at many different regionals each year, tells you how important this is to the game itself.
Look forward to seeing you all at Hartford.
Unread 17-02-2008, 17:35
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Just curious, how many teams did the IR and how successful was it?
-Josh Murphy-
Unread 17-02-2008, 18:43
Kendal Reed's Avatar
Kendal Reed Kendal Reed is offline
Hatless Hacker
FRC #0007 (007)
Kendal Reed will become famous soon enoughKendal Reed will become famous soon enough
Send a message via AIM to Kendal Reed
time++;
Um... what kind of drive system are you expecting? I can't think of any where it would make sense to use the same value for the left and right PWMs. Most systems have the left and right motors facing in opposite directions and would therefore use value pairs where one side's value is equal to 255 minus the other's.
And I think it's gonna be a long, long time... till kickoff brings us round again to find... we're not the same six weeks a year... We're all robot men.. burning out our brains; we love it here...
Yesterday is history.
Tomorrow is a mystery.
Today is a gift;
that's why we call it the present.
Good heads, Fezzik. Bad heads, Speed Racer. One robot, two faces.
Unread 17-02-2008, 18:49
Billfred's Avatar
Billfred Billfred is offline
Actually, it depends from setup to setup. Currently, a dashboard hooked to our robot's OI would read 255 on both sides when the robot's going forward--but because we flipped one side of our drivetrain's wires. Saves us the programming tomfoolery otherwise required.
Unread 17-02-2008, 18:53
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
A large number of teams that I've seen have figured out that it makes a lot more sense to swap the motor wires on one side of the drivetrain, rather than having to remember to handle it in software.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Suffield Shakedown Scrimmage MWTrek Off-Season Events 58 22-02-2008 01:28
2008 Pre-Ship 2008 Suffield Shakedown Scrimmage Webcast stevek General Forum 0 13-02-2008 23:55
LIVE Webcast from the Suffield Scrimmage xtremedarkness General Forum 11 20-02-2005 21:44
SBPLI Observations ZZII 527 Regional Competitions 3 18-03-2004 21:46
GLR Observations archiver 2000 5 23-06-2002 22:20
