Go to Post More resistors Igor! - BitTwiddler [more]
Unread 17-02-2008, 02:33
Triscuit Triscuit is offline
FRC #1258
Triscuit is an unknown quantity at this point
FRC Competition Control System
Does anyone have a Competition Control System that they have made for practice purposes with other teams that have the same functions as the control system used by the official in the regionals and championship? If so, would you be able to post directions on how to make one. Just to clarify, this is the system that connects up to the competition port on the operator interface. And i think I already know the answer to this, but is the Official Competition Control System that is used during the Regionals and the Championship available?
Unread 17-02-2008, 02:43
Re: FRC Competition Control System
I'm pretty sure SCRRF has one. Not sure about plans.
As for the official one being available, I think the answer is, if you rent a field from FIRST for a post-season, the control system comes with it. I don't think the control system can be rented/purchased separately.
Unread 17-02-2008, 10:20
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
If you rent a field in the off season, yes everything you need to run the event comes with the field.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 17-02-2008, 10:56
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Building your own competition controller can be done to some extent, granted you wont have all the same functionality of the IFI-Competition Controllers but you can get a limited alternative to it. Search around on the forums and you can find out how to change the team numbers to enable multiple channels so that you can use more then one un-tethered robot at a time in your own shop, and you can also construct a competition port dongle to enable and disable the robot and turn on autonomous modes. With this information and a little bit of elbow grease you can build something to turn on more then one robot and put them in autonomous mode together.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 18-02-2008, 00:58
FRC #1258
Yeah, I know how to change team numbers and such for untethered practice with other teams, I'm just curious if someone has made their own version of the competition system that controls all the robots on the field and has plans for it that they could share.
Unread 18-02-2008, 01:38
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Well, it's pretty easy to wire a global disable/autonomous switch, but since the competition port protocol is proprietary, i don't think that channel switching is possible (other than the team-number-MSB trick).
Unread 18-02-2008, 01:59
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
no.. one of our previous mentors created one but we used the wrong power supply or something and it burnt up.... but it did everything from changing channels to disabling individual robots and even setting the team color led for red or blue alliance
Unread 18-02-2008, 10:23
That's pretty cool!
Too bad the rest of us will never figure out the protocol
Unread 18-02-2008, 23:21
FRC #1258
Can you or your team contact him? And do you guys still have that old system around? If so, maybe you could post a few photos of it and write what it looks like he to it to make it work.
Unread 18-02-2008, 23:24
One thing I remember about the 2006 SCRRF scoring/field control unit is that the whole thing ran with a laptop (visual display) and a VEX controller. I'm just not sure how. You still had to bring your own radio, though.
Control System wmatt2014 Control System 9 01-02-2008 09:56
**FIRST EMAIL**/FRC Robot Control System Survey Mark McLeod FIRST E-Mail Blast Archive 4 11-09-2007 00:45
Control System archiver 2000 0 23-06-2002 22:51
control system archiver 2000 1 23-06-2002 22:04
Control System Power Al Skierkiewicz Technical Discussion 0 25-03-2002 09:04
