Go to Post FIRST is similar to real life in that nothing is perfect and you have to deal with the circumstances as they arise and make the best of it! - Sean_330 [more]
Unread 11-02-2008, 11:37
cjohnson cjohnson is offline
None #2447
cjohnson is on a distinguished road
New Backup Battery Circuit
Hey guys,
I’m posting a new battery backup charging circuit. The one from ifirobotics does not work. This one is much simpler and uses fewer parts. We have been using this one for about 2 weeks.
Cjohnson
Team 2447
Unread 11-02-2008, 13:40
Re: New Backup Battery Circuit
Thank you for contributing this. I have a few questions, however.
First, you say "The one from ifirobotics does not work." We used it last year, and we're using it this year (with the addition of a series diode on the input). It's working fine for us. What's not working for you?
Second, you've labeled it "FIRST Backup Charger". Is it from FIRST, or is it your own design? Putting FIRST's name on it implies that it's somehow official.
Third, I'm concerned about your apparent use of a 3A fuse in the main breaker panel. That violates the rules. You have to use one of the 20A KOP breakers for custom circuits. You are permitted to use additional fuses as part of your custom circuit, but you still need the 20A snap-action breaker.
Finally, can you describe the operation of this circuit? For starters, the transistor on the regulator's voltage adjust pin is not self-explanatory.
Unread 11-02-2008, 14:29
Cjohnson,
I like some aspects of your design, but I think the battery in question wants to be charged at no higher than 1/10 C or 70 ma without a smart monitor. With different electronics driving the charge rate and monitoring the battery, you can charge at 1/3 C or about 230 ma. Any greater current than this might damage your battery or worse.
Unread 12-02-2008, 12:49
None #2447
New Ver 1.1
Changes
R3 = 3 Ohms (.2A peak current)
Title FIRST changed
For more information please go to http://cache.national.com/ds/LM/LM117.pdf Page 21
Application 906329
Unread 12-02-2008, 13:36
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
CJohnson,
One thing I noticed is that the schematic in the National data sheet which you reference shows the battery as the only load in the charging circuit. If you plan on connecting the output of your circuit to the RC backup battery input, which you must do, then you'll provide a short circuit around R3 through the RC's ground connection back to the circuit breaker panel. I think that'll eliminate any current limiting ability of R3.
Steve
Unread 12-02-2008, 15:33
Cjohnson,
I thought I had seen that circuit before. This charger is meant for a lead acid cell which requires a constant voltage but current limited source. In operation, excessive current (through the battery and R3) is prevented from flowing as the transistor reduces the value of R2 and thereby reduces the output voltage until the current is stable at the design peak.
NiCad cells require a constant current for charging. As Steve has pointed out above, R3 is shorted by the sneak around ground through the RC, the backup battery connector and the robot common wiring. With R3 shorted this circuit produces an output voltage of 7.61 volts up to the cutout current of the LM317. C, sorry I didn't catch this before. I feel I mislead you with my earlier post.
Unread 12-02-2008, 18:02
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Originally Posted by cjohnson View Post
Hey guys,
Cjohnson
Team 2447
I agree, it blew up our backup battery!!!!!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 15-02-2008, 18:08
None #2447
Sorry folks, you are right about the ground shorting out R3. On of my team member told me it was isolated. I finally got my hands on the controller and did some measurements and circuit Version 2.0 I have posted. This design I was bit more conservative at 100 ma charge rate. I also have the charge characteristics curve if anyone needs it.
CJ
Unread 15-02-2008, 18:42
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
On of my team member told me it was isolated. CJ
Is this the same person who told you the IFI circuit didn't work?
Seriously but...
The IFI schematic that was posted until mid-season last year was missing a connector, but once that was ironed out, it really works pretty well.
We used the camera last year and it runs exclusivly off the backup battery. We never had ANY problems with a non-charged battery.
Phil Malone
http://www.GEARSinc.org
Unread 16-02-2008, 22:55
Barak Shelef's Avatar
Barak Shelef Barak Shelef is offline
FRC #3316 (D-Bug)
Barak Shelef will become famous soon enoughBarak Shelef will become famous soon enough
We currently use the IFIRobotics diagram on our robot and it works fine but it keeps on working Even when we disconnect the main breaker it keeps on powering the _WHOLE_ system (RC, Victor speed controlers, Spike Relays and w/ teather even the OI ).
I have a feeling it's either because we've missed a diode somwhere (unlikly :S), or because we connected the inputs via the main power block. should we connect it via the fuse pannel and ground bank?
Unread 17-02-2008, 01:57
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
You're missing a diode in series from the input. That should do it.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 17-02-2008, 11:01
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You should also run it to the breaker panel using a 20AMP circuit breaker, and then use a 1.5AMP inline fuse.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 18-02-2008, 01:27
FRC #3316 (D-Bug)
thanks for the tips, guys, i already drafted the new circuit and chose the components. gonna go and by them along with some spare potentiometers and control LEDs today.
backup battery charger circuit help babylyn90 Electrical 4 06-02-2008 18:11
Need help with build a custom circuit for the backup battery midway78224 Electrical 7 09-01-2008 20:17
Backup Battery Tottanka Electrical 31 06-01-2008 22:41
Backup Battery Charging Circuit David55 Electrical 7 25-02-2007 23:37
backup battery nirty Electrical 1 08-02-2006 14:40
