Go to Post Mmmmmmmm. Donuts! - Sean Schuff [more]
Unread 17-02-2008, 11:44
dtengineering's Avatar
AKA: Jason Brett
Re: CIM Pinion issues in Toughbox
Originally Posted by squirrel View Post
The key and clip were installed just as shown in the picture in the Toughbox User's Guide, shown here.
Well... looking at that picture, then, and hearing another report of this having happened, this may well be a design issue that AndyMark may wish to address in future toughbox/gearbox designs. Like you say, it is easy to fix... when you have the motors out.
Fortunately the biggest design advantage of the toughbox over previous KOP gearboxes is how easily the motors come out. In most cases teams can pull their motor without pulling the gearbox.
We'll keep our eyes open for this... we may even be able to check it out through the lexan panel.
Jason
Unread 17-02-2008, 13:11
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
We had the same problem, with the keyways being to small to work and that they would fall out. Infact we had the same thing happening during our testing, thus, we need to open up the toughbox and rebuild the gear box, which promply fell on the floor and was covered with hair and metal shavings....
Also the CIM came lose and needed to be reattached.
Is now an engineer thanks to FIRST.
Unread 17-02-2008, 15:53
XXShadowXX's Avatar
They call me Cody.
Well guess what, the bot did break down when we tested it and i need to rebuild it, and your keyway trick worked thnxs.
Toughbox broken Evert Kit & Additional Hardware 5 05-02-2008 23:43
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
