Go to Post The Championship, The Championship Event, The World Championship, The international Championship, Internationals, Champs, Nationals, Nat's, ATL... I just call it the best time of my life. - Kyle [more]
Unread 16-02-2008, 15:47
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
One joystick drive
Hi,
I'm trying to get something better than the default one joystick drive, but I don't really understand the concept of turning the x and y joystick values into values for each wheel motor (2 motors).
I'm planning on doing something along the lines of using a lookup table to make the robot more handlable, using thisa function instead of a look up table:
long ramping (unsigned char ramp)
    long answer = 0;
    answer =  ((long)ramp - 127);
    answer = ((answer) * (answer) * (answer));
    answer = ((answer) / (128 * 128));
    answer = (answer) + (127);
    return answer;
Can someone explain the concept for turning the joy stick values on each axis into something for each motor?
Thanks
edit - sorry for the typo in the name of the thread, I can't change it.
Unread 16-02-2008, 22:41
cmptrgy412 cmptrgy412 is offline
Robohawks Programmer
AKA: Jacob G
FRC #1985 (Robohawks)
cmptrgy412 is an unknown quantity at this point
Re: One joystink drive
Sure. What you should end up having is code that looks like this:
// on our joystick the x values were inverted
int nTurn = ramping(128 - p1_x) + 127;
int nSpeed = ramping(p1_y - 127) + 127;
int left =  (int)Limit_Mix(2000 + nSpeed + nTurn - 127);
int right = (int)Limit_Mix(2000 + nSpeed - nTurn + 127);
// pwm01/pwm02 corresponds to motor PWMs.
pwm01 = left;
pwm02 = 255 - right;
The nTurn and nSpeed will be adjusted based off your ramping.
the left and right values go through a typical 1-joystick function.
Then you just assign those values to your motors.
Unread 17-02-2008, 00:37
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
DO you want the explanation of the one joystick formula... how they are derived? It's a bit long winded but not complicated. If that's what you want I can post it.
The function you are showing creates a curve based on the cubic values of the inputs. This makes the joystick less sensitive to start up and more sensitive once the bot is going.
Not sure you can "improve" on the one joystick formulas but you can customize them.
Unread 17-02-2008, 11:57
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
The ramping function that BronxBomber gives just cubics the input. This means that a little push from neutral doesn't move the motors too much. Otherwise, your motors will start moving too quickly too soon.
Next you need to know what Limit_Mix function does. It takes a value and bounds it to be between 2000 and 2254, the subtracts 2000, and returns a value from 0 to 254.
The first call to Limit_Mix is
You add 2000 because of the nature of the Limit_Mix function. If p1_x and p1_y are both neutral, then you get 2000+nSpeed+nTurn which is 2254, so you need to subtract 127 to make it 2127 (neutral). Finally, if the y-axis is near 255 (going forward), you want the left wheels forward, so you add nSpeed. If if the x-axis is near 0 (turning right), then nTurn is near 255 so you add nTurn since you want the left wheels going forward as well.
The next call to Limit_Max is
If both axes are neutral, this becomes 2000+127-127, so you have to add 127 to make it 2127. For the same reason described above, you add nSpeed. And for the opposite reason of above, you subtract nTurn.
I know this was complicated, but does it sort of make sense?
Unread 17-02-2008, 12:21
That makes perfect sense! After running that Limit_Mix logic through my head with the joystick in each direction it's really quite simple
one wheel drive Simon Strauss Technical Discussion 11 16-11-2005 23:58
One Joystick Drive mattsavela Programming 20 19-05-2005 21:28
FIRST's one hour drive Duke 13370 Motors 4 25-02-2003 17:29
one stick drive Hendrix Programming 3 14-02-2003 20:53
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
