Go to Post It's possible to do nearly anything with enough resources and ingenuity. - Madison [more]
Unread 17-02-2008, 13:11
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: CIM Pinion issues in Toughbox
We had the same problem, with the keyways being to small to work and that they would fall out. Infact we had the same thing happening during our testing, thus, we need to open up the toughbox and rebuild the gear box, which promply fell on the floor and was covered with hair and metal shavings....
Also the CIM came lose and needed to be reattached.
Is now an engineer thanks to FIRST.
Unread 17-02-2008, 15:53
XXShadowXX's Avatar
They call me Cody.
Well guess what, the bot did break down when we tested it and i need to rebuild it, and your keyway trick worked thnxs.
Toughbox broken Evert Kit & Additional Hardware 5 05-02-2008 23:43
Toughbox Assembly mjgard General Forum 39 16-01-2008 19:27
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Converting the Bosch Metric Pinion into an English- Specification Pinion evolution Motors 3 28-08-2004 16:30
