Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 17-02-2008, 14:48
marine14514 marine14514 is offline
Stephen W.
AKA: Stephen W.
FRC #0340 (GRR)
marine14514 is an unknown quantity at this point
Send a message via AIM to marine14514 Send a message via Yahoo to marine14514
Program PIC with Basic Stamp
I have a parallax BASIC Stamp programmer and intend on using it to fix our IR board by using it as the programming interface. However I do not have experience with using this particular STAMP Board to do it. I would like to know how to use the Stamp Board to connect to the ICSP header and reprogram it. What is the best way to do this? I have MPLab and can download other necessary programs if I need to.
Thanks,
Stephen
Team340
Unread 17-02-2008, 14:59
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Re: Program PIC with Basic Stamp
What exactly are you trying to do? Are you using the Stamp processor to program the PIC or are you using the board as the programmer and translating the Stamp program lines to PIC program lines? I use Atmel, but I'm pretty sure ISP headers for Microchip are standardized. Look for data sheets from Microchip.
Unread 17-02-2008, 15:06
Stephen W.
AKA: Stephen W.
FRC #0340 (GRR)
I'm using the Parallax Programmer for Stamp chips in order to put Bob Grieb's Hex code on to the PIC. I need to know how to set it up such that the ICSP on the IR board's PIC can be put into a programming state and have the hex code go over.
Unread 17-02-2008, 15:11
Again, I use Atmel, but I would suggest reading the data sheet for the PIC on the IR board. It should include an interface section that should list the standard ISP header pin out and state changes.
Unread 17-02-2008, 15:30
Here is the data sheet.
Unread 17-02-2008, 15:50
Stephen W.
AKA: Stephen W.
FRC #0340 (GRR)
I already know what pins I need to connect to on the PIC, I just need to know how to interface those pins on the Stamp programmer board so that I can send code to the PIC.
BASIC stamp BS1 John Gutmann Control System 9 10-08-2005 14:33
Portable BASIC Stamp- or PIC-driven Dashboard Viewer... ThomasTuttle Control System 3 24-06-2004 21:38
BASIC Stamp as a server Raven_Writer Technical Discussion 7 23-09-2003 12:16
no basic stamp found! DLyons Programming 7 23-12-2002 22:17
I Need Help with downloading Basic Stamp Program archiver 1999 2 23-06-2002 21:57
