Go to Post anything that craves Mountain Dew is definitely intelligent enough to be dangerous. - IMDWalrus [more]
Unread 17-02-2008, 16:52
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
Multiple Robots, Please Help
Alright, I'm pretty much at my wits end here. For practice purposes we have been attempting to get two robots working at once. The other robot, 2005, we would like to run defense on our 2008 robot. I know that to do this you have to change the channel on the OI.
However, I have tried everything to change the channel. I've looked at the white paper here on CD, I've looked in the FAQ on IFI's website and I've looked at the OI manual PDF on IFI's website. I've gone through every step that I can find and through all of it the channel stays at 40.
Is there any help someone can give me? Some small step that they just assume I would know? I wasn't on 973 during the 2005 year so I wouldn't know if theres some special trick for the 2005 box....
Unread 17-02-2008, 16:55
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Multiple Robots, Please Help
2 pins need to be jumped on the OI for you to be able to change the channel, they are pins 12 and pin 8 I believe. This info is from an old IFI OI manual:
Connect pin 12 to pin 8 to provide additional channel access.
You can do this with a DB-15 connector and backshell or through other means.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 17-02-2008, 17:00
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
This competition port document from IFI says the same:
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 17-02-2008, 20:43
The Lucas's Avatar
CaMOElot, it is a silly place
That connection no longer needed on 2005+ OIs. However your OI for 2005 bot might actually have a 2004 or older OI (by some mixup) so the connection would be needed. Check the year of the OI by the looking at the sticker on the top of the OI.
Also have you tried to change channel on your new 2008 OI by setting the MSB bit of team number? (no reason 2008 has to be on channel 40)
Robot Inspector
Running Multiple Robots with the old Radios cbale2000 Technical Discussion 4 18-10-2007 19:40
Opinions Please - International Robots & Vision Show indieFan General Forum 0 19-04-2007 12:52
Using multiple robots at a display? Adam Richards Control System 5 02-04-2005 12:44
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
please help us, pretty please :) archiver 2001 0 24-06-2002 03:13
