master code
What is the master code for the robot controler? Referring to easyc pro
Please any help will be appreciated. Thanks |
Re: master code
I believe the master RC code for EasyC and MPlab are the same... So you should be using: http://www.ifirobotics.com/rc.shtml Scroll down to the bottom.
(If someone could confirm the RC code is the same regardless of EasyC...? Not too sure) |
Re: master code
there is no real master code for EasyC, because it's just drag and drop. All of the external libraries and functions are already included for you, so all you need to do is start looking at what all the different functions do.
Re: master code
![]() And yes, the mastercode is the same no matter what you program the user chip with. You don't have to update it unless an update is issued (read team updates). |
| Master code? | SidneySalvo | Programming | 1 | 07-02-2008 23:28 |
| Master Code | gabrielse | Programming | 1 | 28-02-2007 14:30 |
| Master Code | The Vrooman | Programming | 8 | 07-02-2007 17:23 |
| Master Code 11? | SteveO | Programming | 5 | 22-04-2005 19:48 |
| Master Code? | HolyOne207 | Programming | 4 | 12-01-2005 22:32 |
