#17
Re: IR Board Problem
Thanks! Ours went down last night and I cannot find a pic programer. I will give this a try.
#18
Humm, sorry to hear that. Did you unzip the hex file?
I didn't have any problems and I used the same file you mentioned. Can you read from the device without error? I wonder if your PC serial port voltage is too low, I saw mention that that could cause problems when I was researching. I guess since it worked for me, I don't have much insight into figuring out what can go wrong. |
#20
LoadHex: Ignored 316 locations at addr 0x000400...0x002008 . Code:
Couldn't find "devices\PIC16F87.dev", please borrow/copy from MPLAB ! |
#21
what programmer are you using? (ICD2?)
what software do you use with it? |
#22
Check out the screen shot in my powerpoint slides. Under the interface tab I selected "JDM (2) for serial port" under Interface Type, and then I loaded the ElCheapo_PCB.ini for the definition file. This was via trial and error before I got "success". Maybe that will help if you didn't do that.
#23
The IR PIC hex file has also been posted by FIRST on their Additional Technical resources page
http://www2.usfirst.org/2008comp/Manual/FIRSTIR.HEX |
#25
To anyone with IR board problems that's coming to the oregon regional, team 2273 (shameless plug) will graciously give you a hand in getting it to work. It'd be a shame for any teams to not get their robot to do at least SOMETHING in hybrid. We have a PicKit2 and the know-how to get your boards up and running.
#26
I'll keep fiddling with it and post if I have any success... |
#27
i have the same problem as DarkJedi613
No luck so far. |
#28
I got it to work!
The things I changed (note I don't know if all these are necessary): Devices Tab: Choose PIC16F87 Options Tab: Provided the MPLAB devices directory (you really only need one file - "PIC16F87.dev" and it was asking for a 16F716 algorithm, but also providing PIC16F716 didnt help). Interface: Interface type: JDM (2) for serial port Custom interface definition file: ElCheapo_PCB.ini And that was it! Note: it gave me LOTS of errors, but the device works now (through test it with a remote) so I'm not sure whats up with that. I just tried it again on my laptop (through a USB to serial adaptor -- I changed the Option "I/O Port Access Driver" to "no direct access at all, only use win API"). This DID NOT work however -- I could not even erase the board. It is possible a true serial port would work however. Good luck! |
| Programing IR board problem | Shivang1923 | Programming | 5 | 16-02-2008 22:55 |
| IR board problem | AmitCarmeli | Electrical | 3 | 09-02-2008 18:53 |
| Another IR Board Problem | C222 | Electrical | 2 | 13-01-2008 17:36 |
| Do you have a problem with the IR Board? | DonRotolo | Control System | 5 | 07-01-2008 23:57 |
| Perf Board = BS2-IC Carrier Board? | indieFan | Electrical | 2 | 16-09-2004 08:28 |
