Go to Post CAD or it didn't happen - R3P0 [more]
Unread 17-02-2008, 22:15
Gizmo2417 Gizmo2417 is offline
Gizmo
FRC #2417 (Robocougars)
Gizmo2417 is an unknown quantity at this point
Connecting IR Board
Tomorrow is our last day of work on the robot, and we're just getting to the IR board, so quick responses are highly appreciated.
To power the board I just come in from the breaker panel and connect to pins 1-2, then go back to the breaker panel with a ground wire from 3-4 right?
If so, then how do I get signals to the board from the controller? Connect it to the white wire of a PWM cable attached to the digital IO?
After we get that, programming help would be awesome. Thanks!
Electrical, Structure, Programmer, Drive Train, Thinker, WebDesigner, Pneumatics, Peace Keeper, Advisor, Ect...
Unread 17-02-2008, 22:41
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Connecting IR Board
The IR board will have four connections to the RC, one for each of the signals. The exact pins those signals are from can be found in the IR board manual. You will need to use a minimum of two PWM cables to hook up the four pins. One can go across three sensor pins, and another can fit normally.
Programming would depend on what application you're using.
Unread 18-02-2008, 00:06
Gizmo
Ok, that's what I thought. I read the manual. I'm assuming I'm correct in wiring the board?
Also, I use easyC. Thanks!
Unread 18-02-2008, 00:17
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
This might be helpful
http://www.youtube.com/watch?v=ANo4sKunvXc
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 18-02-2008, 00:54
Gizmo
Thanks, I'll look into that when I get to a computer with faster internet...
Unread 18-02-2008, 01:58
Stvn's Avatar
Stvn Stvn is offline
FIRST Competition Competer
AKA: Steven Rhodes
FRC #0100 (WHS/CHS - WildHats)
Stvn is an unknown quantity at this point
Send a message via AIM to Stvn
As an alternative way to power the board, you could connect the power and ground wires to an unused PWM output. The 7.2 volts from that is enough for its operation.
Here's the code we're currently using to get the inputs (using WPILib):
unsigned char Previous_Value;
int GetIR (void) {
	unsigned char IR_Value;
	IR_Value=GetDigitalInput(IR_1)+(GetDigitalInput(IR_2)*2)+(GetDigitalInput(IR_3)*3)+(GetDigitalInput(IR_4)*4);
	if(IR_Value>0) {
		Time=0;
		Previous_Value = IR_Value;
		return IR_Value;
	} else if(Time>250) {
		Time = 0;
		Previous_Value = 0;
		return 0;
	}else if(IR_Value==0) {
		++Time;
		return Previous_Value;
connecting sensors guy_rom Electrical 4 01-02-2008 13:21
Connecting LCD module to RC David55 Electrical 5 13-07-2006 22:09
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Connecting Switch to RC Mr. Steve Control System 2 28-01-2005 22:37
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
