#16
Re: Holding Down Buttons on the Remote
it is sending out pulses. that would be the same as pushing the button really fast. like for example: if you are sending pulses that drive your robot forward but making the robot "pulse" forward. wouldnt that be legal? because each pulse it doing one action that drives the robot forward a little but. so holding it or pressing it really fast would be the same and drive the bot forward. |
#18
one of our earlier autonomous modes worked like this:
it had two vectors: the forward vector and the angular vector these vectors constantly return to 0 using a linear ramping technique when a forward signal is received from the IR board, it ramps the speed up 20%. further presses of the button will yield more speed (linearly, 20 40 60 80 100) when a turn left/right signal is received, it ramps up the turning vectors inverse-exponentially (to improve turning) there is also a stop command which would reverse the robot for a couple ticks we ended up ditching it because it was too borderline within the rules, the IR signal dropped out at the other end, and we made a better autonomous mode after that. I dunno about the rules though... a single button press always does the same "add 20%" thing, and they arent held down in order to do it. any thoughts? |
#19
Uberbots,
Seems okay - changing orientation by a fixed amount is legal, and I guess the ramping back would be an autonomous thing. seanl, I agree that you could use semantics to get around the "no holding buttons down" rule, but it would be nice to stay within the spirit of GDC's decisions as well as the letter. |
| Buttons, Buttons and more Buttons (2006) | Freddy Schurr | Team Organization | 11 | 14-12-2005 21:36 |
| pic: Holding the big ball | CD47-Bot | Robot Showcase | 12 | 23-02-2004 22:14 |
| Remote Remote Kickoff for Southern California | ChrisH | Southern California Regional Robotics Forum | 0 | 05-01-2004 12:36 |
| Remote Remote Kick off at University High School | George1902 | Off-Season Events | 4 | 04-01-2004 21:05 |
