Go to Post Where's my hammer? I need a bigger hammer. - JaneYoung [more]
Unread 17-02-2008, 21:40
kevin kevin is offline
FRC #2525
kevin is an unknown quantity at this point
master code
What is the master code for the robot controler? Referring to easyc pro
Please any help will be appreciated.
Thanks
Unread 17-02-2008, 22:14
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: master code
I believe the master RC code for EasyC and MPlab are the same... So you should be using: http://www.ifirobotics.com/rc.shtml Scroll down to the bottom.
(If someone could confirm the RC code is the same regardless of EasyC...? Not too sure)
Unread 17-02-2008, 22:43
iwin2000 iwin2000 is offline
iwin2000 has a spectacular aura aboutiwin2000 has a spectacular aura about
Re: master code
there is no real master code for EasyC, because it's just drag and drop. All of the external libraries and functions are already included for you, so all you need to do is start looking at what all the different functions do.
Unread 18-02-2008, 00:21
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: master code
Wrong, I don't think you're talking about the same mastercode as we are
And yes, the mastercode is the same no matter what you program the user chip with. You don't have to update it unless an update is issued (read team updates).
Master code? SidneySalvo Programming 1 07-02-2008 23:28
Master Code gabrielse Programming 1 28-02-2007 14:30
Master Code The Vrooman Programming 8 07-02-2007 17:23
Master Code 11? SteveO Programming 5 22-04-2005 19:48
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
