Re: Mounting the IR board
we mounted it on some insulating foam and bolted it to the robot and added some protections around it.
it seems to work very well |
| Pneumatics Board/Mounting Components | ASmith1675 | Pneumatics | 2 | 06-02-2008 13:47 |
| problems mounting the camera to the 'bot with the default servo/mount set up | Redneck | Programming | 0 | 16-02-2005 20:53 |
| mounting of the small gear directly to the shaft of the drill | Andrew Dahl | Motors | 0 | 19-01-2004 12:18 |
| Mounting weights on the side of the bridge? | archiver | 2001 | 4 | 23-06-2002 23:01 |
| Mounting weights on the side of the bridge? | archiver | 2001 | 0 | 23-06-2002 23:00 |
