Go to Post heh...do the math! - MrForbes [more]
  #151   Spotlight this post!
Unread 19-03-2007, 16:09
Re: The 8.2 (or 8.3) Battery Voltage Bug
We were able to work around it by not using printf or Kevin's serial code. We successfully used IFI's blocking serial libraries without triggering the bug. I do not beleive that Kevin's serial code is the entire problem, as we tried reproducing the problem with just his code several times. Rather, we've decided that it is some wierd interaction between his code and our code.
We replaced all our printfs with DEBUG statements like Kevin's camera code so we could easily disable all printfs before doing anything important.
  #152   Spotlight this post!
Unread 20-03-2007, 17:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I find it scary that the linker is allocating variables such that problems that bad are appearing, and you're using code that could do that.
All variables are statically allocated.
Pointers and arrays are used only a few times in the code.
Issues that bad would suggest that something is very, very wrong at a fundamental level. Try it on another RC.
  #153   Spotlight this post!
Unread 16-02-2008, 07:15
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
We are having the same problem that you guys speak of in this thread, and we can't understand from this thread what the exactly is the solution...
Can anyone please clarify to us what exactly we shoud do?
We are using Kevin's most updated code...
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
  #154   Spotlight this post!
Unread 16-02-2008, 12:38
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Whoa, really? Can you zip up your entire build directory and e-mail it to me?
-Kevin
Kevin Watson
http://kevin.org
  #155   Spotlight this post!
Unread 16-02-2008, 12:49
Tottanka's Avatar
AKA: Liron Gurvitz
I'm sorry for the confusion, everything is ok now.
Thanks a lot though =]
  #156   Spotlight this post!
Unread 16-02-2008, 13:03
FRC #2429
What do you mean everything is okay now? Given the pain the 8.2 bug caused teams in the past, you need to let me know if you actually had this problem, so that I can try to understand it and hopefully provide a fix.
-Kevin
Kevin Watson
http://kevin.org
  #157   Spotlight this post!
Unread 16-02-2008, 13:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We experienced this bug earlier this year. We changed the size of our autonomous code and it went away.
  #158   Spotlight this post!
Unread 16-02-2008, 14:27
FRC #2429
Is this with my code? If you happen to have an archive copy of the malfunctioning code, can you e-mail it to me? Has anyone else seen the 8.2 bug this year (yes, that includes you, over there in the corner)? If you have, please post here.
-Kevin
Kevin Watson
http://kevin.org
  #159   Spotlight this post!
Unread 16-02-2008, 16:24
Tom Line's Avatar
Post Re: The 8.2 (or 8.3) Battery Voltage Bug
We are using your gyro + encoder code integrated into last years ifi default code.
We didn't remove any functional code when we did our clean up - we deleted some old procedures that we were not even calling. We were not close to the memory limits. That's the best information i can give you as we only keep the last 4 days of code - the rest gets deleted.
We're using MPLAB 7.20.
  #160   Spotlight this post!
Unread 18-02-2008, 01:50
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We experienced this bug, I think, twice for the first time tonight. We'll be driving the robot around normally and, without warning and for no obvious reason, it will stop in place and cease responding to all inputs. The OI shows 8.3V and the Code Error light illuminates.
Since I'm not a programmer, I can't say too much about how we have things set up. We're coding manually within EasyC and using two Chicklets for control, if that makes any difference.
I've pointed our programming mentor to this thread, as well as to the document provided by IFI about changing the information in the linker file. I'll update this with more information from him as I come across it.
--Madison--
...down at the Ozdust!
  #161   Spotlight this post!
Unread 18-02-2008, 03:43
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
-Kevin
We have gotten the 8.2 bug on multiple occasions. Sometimes we'll turn on the robot and it'll go freaking crazy (right track at full speed and drive the arm all the way up, fortunately it seems to obey the limit switch and not overdrive it). We'll hit the disable switch and read the OI, lo' and behold it reads 8.2.
After a complete power cycle (kill main breaker and hit the reset button to power off the RC), sometimes we have to do it twice, it'll work just fine.
I believe this code is the 2007 default plus all of the changes we've made. We did not get this bug in any previous years and we don't know what made this happen this year.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
  #162   Spotlight this post!
Unread 18-02-2008, 12:36
FRC #2429
Before this happened had you completed all the steps mentioned in this document?
-Kevin
Kevin Watson
http://kevin.org
  #163   Spotlight this post!
Unread 21-02-2008, 16:52
Tom Line's Avatar
Help!
We now figured out why the 8.2V bug went away last time - it's because we stopped using our practice bot + controller and switched to our new one.
Today we went back to the practice bot, loaded the code that works perfectly well on our competition bot, and it immediately went into the 8.2V bug.
I've deleted and commented out huge chunks of code in an attempt to change the compiled memory footprint however it does not seem to make a difference. Nothing we do with this code seems to correct the problem.
The issue immediately goes away upon loading the IFI default code. Can someone take a look at this and see if there's anything that jumps out at you as to the cause of the issue? Thank you!
We updated the master code to check if that fixed the issue and it did not.
  #164   Spotlight this post!
Unread 21-02-2008, 16:58
Tom Line's Avatar
Just for fun, we got our 2006 board out and used that - no 8.2 error. So we get 8.2 on the 2007 board, but not the '08 or the '06.
That makes me lean toward a silicon issue.
Kevin, if you would like our code, I can email it to you.
  #165   Spotlight this post!
Unread 21-02-2008, 17:40
FRC #2429
Yes, please.
-Kevin
Kevin Watson
http://kevin.org
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
