Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 17-02-2008, 22:56
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
How team 612 Hurdles
http://www.youtube.com/watch?v=VbGBxKjMlh0
See you at VCU and Buckeye!
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 17-02-2008, 23:20
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
Re: How team 612 Hurdles
Hey guys, do you think the robot will shoot it a bit further if the ball pistons were in contact more.
1. Pick up balls with roller wheels
2. Lift up elevator to proper height
3. Drop pistons into position
4. Fire
5. Jump up and down
6. Retract pistons
7. Lower elevator
8. Repeat
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 17-02-2008, 23:27
Arille's Avatar
Arille Arille is offline
FRC #2135
Arille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to beholdArille is a splendid one to behold
Send a message via AIM to Arille
Hey, thats pretty sweet! We were thinking of the same idea (we're working with a 12" or 24" actuator... any opinions on which one? Also, what PSI did you guys use to launch? Isnt there a rule that only 60 psi can be used or something? That is really cool launcher. Congrats!
Team 2135: Presentation Invasion
Silicon Valley Regional 2007 Rookie Inspiration Award!
Unread 17-02-2008, 23:36
AKA: Shan Rammah
two 24 inch pistons (2" bore) running at 60psi.
I will try to get the other video of us shooting, after a little tweaking we found that the ball travels a much further distance when it is resting on the pistons (in the video the pistons and the ball are separated by about 5-6 inches).
Unread 17-02-2008, 23:38
FRC #0612
Team Role: Mascot
If you have the weight I'd say go with the 24" pistons, they have a nice follow through.
Unread 17-02-2008, 23:51
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
this looks awesome guys. congrats on a good job
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 18-02-2008, 06:37
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
Good job guys!
Nice and quick hurdling.I'm sure you'll do great at the matches.
However, there is a little something team 2669 KY Bots would like to present to you:
We've organized FIRST tips on safety for shooting mechanisms into a small presentation.
Check it out:
http://www.chiefdelphi.com/media/papers/2082?
P.S. I know it's way of topic, but is there anything wrong with our team name?
I mean KY ? We heard someone saying that we better change it in case we get to Atlanta.
I was wondering what could be wrong about it..
Visit team 2217 channel:
http://www.youtube.com/profile?user=team2217
2007 Israel Regional GM/Technion Rookie All Stars
Participated in 2007 Atlanta World Championships (Newton Division)
______________________________________________
Visit team 2669 channel at:
http://www.youtube.com/user/team2669
Unread 18-02-2008, 09:04
AKA: Shan Rammah
When we started to build this shooter we knew safety was going to be key. First of all when the robot is not used we disconnect our source for air and also leave the leak valve open. Second the pistons will only allow deployment when the shaft position encoder is correct for our shooting height. We have a long list of things we do before we fire. But thanks for the tips, some of them are quite helpful.
Unread 18-02-2008, 22:59
FRC #0612
Team Role: Mascot
Also the secondary driver needs to push a series of buttons just to get the pistons to drop down, let alone to get the big pistons to fire.
Unread 19-02-2008, 00:19
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Smile Re: How team 612 Hurdles
As long as you don't have to pat your belly and rub your head at the same time.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 19-02-2008, 11:39
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Looks good, see you guys at VCU.
Unread 19-02-2008, 11:44
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
we're using a 2" 24" bore its a air hog no two ways about it. It took some creative plumbing to get it to work.
Hurdles? Vanquish General Forum 3 18-01-2008 17:02
Team 612 on CBS deshirider430 Robot Showcase 8 12-05-2006 21:06
TEam 612 Websites RoboMadi General Forum 2 19-03-2006 23:59
Team 612 Teaser RoboMadi Robot Showcase 5 12-02-2006 19:00
Team 612 Video psquared Robot Showcase 4 25-03-2005 09:08
