Go to Post Wow! Shipping to Israel?!? It's exciting to have a fan from so far away :D - stens987 [more]
  #46   Spotlight this post!
Unread 23-01-2008, 22:04
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Encoder Code
Originally Posted by John Hooper View Post
I have MPLAB 8.1, compiler 3.1 set up with Kevin Watson's FRC code, which does compile.
Open up teleop.c in your editor. The one function you really need to know about is Teleop(). During teleoperation mode this function is called when new data has been received from the operator (i.e., robot driver) interface, which has a bunch of joysticks attached. This happens every ~26ms. The idea is to take the driver's input and use it to control a motor. The simplest case would be something like:
pwm07 = p1_y;
This maps the y-axis of the joystick attached to port one of the operator interface to the motor controlled by PMW output seven. The variables are unsigned chars where neutral is 127, full reverse is 0, and full forward is 255. pwm07 and p1_y are #defined in ifi_frc.h. The default mapping that has been used in the past can be found in ifi_code.c/Default_Routine().
-Kevin
Kevin Watson
http://kevin.org
  #47   Spotlight this post!
Unread 18-02-2008, 10:02
avitzur avitzur is offline
avitzur is an unknown quantity at this point
clock cod
I am using the 'frc_encoder' from 2006 as a base project and C18 2.4
I wont to use your new 'clock' file from 2008 but it looks for 'ifi_frc.h'
what can i do ??????
avi
  #48   Spotlight this post!
Unread 18-02-2008, 12:56
FRC #2429
Re: clock cod
avi
Replace that #include statement with this one: #include <p18cxxx.h>. If you're using 2006 code, it's important to make sure you follow the steps in this document too.
-Kevin
Kevin Watson
http://kevin.org
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
