Go to Post Really heavy snow is different in Minnasota and Oklahoma... It has to be pretty bad up there. - thatoneguy23 [more]
Unread 18-02-2008, 10:41
adam2177 adam2177 is offline
FRC #2177
adam2177 is an unknown quantity at this point
RC +5V Pin Voltage
Has anyone actually measured the +5V pins on their RC under normal operating conditions? I was curious and measured ours and both our 2007 and 2008 RC output 6.9V on these pins under no load. I thought the RC had an onboard 5V regulator which should mean these pins are at 5V, not 6.9. If the output from these pins is not actually regulated, then this would make more sense.
Unread 18-02-2008, 10:44
Re: RC +5V Pin Voltage
The positive voltage on the PWM outputs is connected to the backup battery not to the internal 5 volts supply. The voltage pin on digital and analog inputs is connected to the internal 5 volt supply.
Unread 18-02-2008, 10:45
Racer26 Racer26 is offline
Al is correct. Are you sure you measured the pins claiming to be 5V and not the ones claiming 7.2V?
Unread 18-02-2008, 10:54
FRC #2177
No, I measured the +5V pins in the analog and digital banks. I am aware that the PWM pins are connected to the backup battery.
Unread 18-02-2008, 11:08
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
the gnd to Positive (black and red lines) should be 5v +- .25v. Ours is usually within that range.
As a side note, on our bot the gnd and 5V was shorted without harming the RC, but of course things did not work.
Doug Leppard
Unread 18-02-2008, 11:11
FRC #2177
Thanks for the info. I'm concerned we either have a bad regulator our the gear tooth sensor lines are shorting and sending 12V into the 5V lines.
Unread 18-02-2008, 13:07
AHHHH! Remove the GTS and check the voltage again. I am betting a wiring error on the GTS swapping the 12 volt and 5 volt supply lines. Breaker should have been tripping.
pin voltage tseres Programming 2 13-01-2008 14:30
OI Voltage JAH Electrical 7 12-11-2004 20:01
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
