Re: Lap Counter Wieght
The flag is not part of the weight this year (<R13>), and the lap counter is attached to the flag. Based on that, I would say that the counter does not count in your weight, but the PWM cable run to the flag holder does.
Eric is correct, the flag is inserted in a rubber stopper and the lap indicator is mounted to the stopper. There is a requirement that there be a clear area around the top of your flag holder 2" in diameter for at least 180 degrees and visible from above. Please be sure to mount your flag holder at the specified height. Please review R17 and R18 to insure you are in compliance and the top of the flag holder is specified at 51" +/- 1" per Team update 5.
| Lap counter, What port? Mounting Rule 18 | ericsundbergva | Technical Discussion | 11 | 19-02-2008 08:22 |
| Lap Counter??? | RoboGeek99 | Technical Discussion | 3 | 25-01-2008 19:33 |
| So uh yeah... How 'bout that lap counter? Also Metallica. | Tach'ko | Electrical | 11 | 21-01-2008 12:01 |
| Lap counted when lap indicator crosses line? | Madison | Technical Discussion | 6 | 08-01-2008 09:15 |
| pic: IR Lap Counter on the Manchester Kickoff Field | ahecht | Extra Discussion | 13 | 06-01-2008 21:38 |
