Go to Post I remember as a kid thinking how high a team number like 834 was. - Dancin103 [more]
Unread 17-02-2008, 17:01
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Relays Reversing On Their Own
I have 5 relays that will reverse on their own at various times. Nothing has to be happening to make this take place. I changed the controllers that are controlling these relays. There are no sensors or limits on these. They are not programmed to be controlled in reverse, just forward. There is nothing fancy in the code -- I did add set relay forward to off and ignore reverse before the loop in operatorcontrol. ????
Unread 17-02-2008, 22:33
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Re: Relays Reversing On Their Own
I remember something from past experiences (I might be wrong), that the Tank control block and the OI to Relay (or OI to anything) shouldn't be 'placed in the same immediate loop'. I could be thinking of another problem, but I think you should try this:
Again, I'm not sure this would work, but try it anyway. Make a function and put in a 'Digital OI Input' and have it save to a variable (be careful, this var has to be an 'unsigned char'). Then have an If statement test to see if that variable == 1. Then put a SetRelay command and set it to forward. Following the If, i put an Else, and a SetRelay to set the relay to neutral.
I have an attachment picture which illustrates this.
I hope it helps.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 18-02-2008, 11:27
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We have never seen any issues like you describe and your program looks fine.
You don't need to break up OI to RC based functions you can slap them in line just like you have.
I would check and make sure your backup battery is charged as it might be the RC reseting under a low main battery. You may want to fire up the IFI dashboard
and see if your joysticks have a messed up button.
Unread 21-02-2008, 10:09
Mike Smith Mike Smith is offline
FRC #1561 (Robo Ducks)
Mike Smith is an unknown quantity at this point
We had the same issue last year - and our pneumatics would not work. We had to reset the robot from the OI. We had a new programmer this year, and totally re-wrote last years program, and the relays would reverse on their own. I could turn the robot on, and let it set there doing nothing. At random times the relay would reverse, because a cylinder would actuate on it's own.
This year, it has happened twice - which is much less frequent than last year.
We had a fresh main battery, and a fresh backup battery also. So far we have had no luck finding the problem. We even tried to reinitialize the relays every time through the loop - to no avail.
Maybe we can solve this problem eventually!
Thanks,
Mike
1561
Unread 21-02-2008, 10:35
This type of problem is capable with PWM cable that are not fully inserted. If you are using the newer Spike it is more difficult to get the cable fully inserted. Remember that the Spike input is a wire for each of two relays, it is not a PWM signal. If one of the inputs is intermittant and meant to be pulled to ground, the Spike will pull up when the connector is open. If your Spike has had the input spread open, it is possible to have an intermittant connection.
Reversing motors railerobotics Programming 5 16-01-2006 18:36
Reversing controls? Calvin Programming 10 14-03-2005 22:46
Are your solenoids firing on their own? Mr. Lim Pneumatics 7 23-02-2005 04:19
Who has their own, personal robot? Caleb Fulton General Forum 1 14-04-2003 10:26
