Go to Post I was on the same plane as 365 returning from Atlanta to Philadelphia last year. The whole rear half of the plane was neon green. - Lil' Lavery [more]
Unread 18-02-2008, 11:58
PhilM PhilM is offline
FRC #0937
PhilM is an unknown quantity at this point
IR sensor corruption help
We have a problem with our IR chip. For some reason the fourth button we assigned to the IR chip is messing up. When we turn on our autnomous code using a paperclip in the competition spot in the controler, the fourth button's command starts going on it's own. The remote we have set up was not pointed at the sensor, and nothing was pressed. We quickly removed the paperclip, and things worked again tried it again, same thing happened.
So we tested again by commenting out what button four did on the program. The other three buttons and their reactions worked just fine. We put the missing part of the program back in and BAM! Same problem.
Then someone looked up the update from FIRST, and it said that the IR chip was becoming faulty under circumstances we had been doing. (Leaving the battery plugged in all the time and leaving it hooked up to the robot)
Is the IR chip our problem with the program, and is there any way to fix it?
Or is our problem with our program and the IR chip should be perfectly fine?
Please Help!
~Team 0937
IR sensor???plz help bilal1219 Programming 3 12-02-2008 10:05
Sensor Help itzrobz Programming 1 05-02-2006 14:07
3DS File Corruption Capt. Slash 3D Animation and Competition 4 28-01-2006 13:21
table corruption... round 2 Brandon Martus Announcements 0 18-12-2001 23:57
table corruption Brandon Martus Announcements 2 20-11-2001 05:16
