Go to Post General rule of thumb: "If it moves and it shouldn't, use duct tape. If it should move and it doesn't, use WD-40.":) - ben_0614 [more]
Unread 18-02-2008, 16:04
Power Up Code Error / System Crash
Hi all,
I'm seeing some weird behavior out of the RC, and was wondering if anyone has seen similar.
We are using Kevin Watson's ifi_sensor workspace as a baseline, and have multiple modules plugged in on top of it, tied together in various ways. Pretty standard stuff.
When the robot is first turned on, there is a code error, and the red light blinks. Upon a reset, the code runs smoothly as expected; resetting the RC after initial boot does not cause this problem. The bug seems to be limited to full power cycles only.
Is there any extra initialization on a cold boot? I believe I may be tripping the watch dog, but can't be entirely sure.
Thanks!
Unread 18-02-2008, 16:16
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Power Up Code Error / System Crash
There's a ton of extra initialization on a cold boot. At the very least, all the inline initialized variables are re-initialized during a cold boot, thus why people often have failed autonomous modes after a field error. There's a fair bit of processor memory clearing and such like as well. If you've fiddled with that code then that might do it.
Unread 20-02-2008, 15:52
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Could you be more specific? On a cold reboot (power up) and upon a reset, the processor vectors through 0x0000 - the reset vector - and then does:
_entry    -> jumps to  _startup
_startup -> sets up stack/frame pointers
                 calls clear ram memory routine to zero in all ram banks (except for F00-F5F)
                 calls _do_cinit which initalizes all ram locations to user declared defaults
                 calls main
main
It should be the same for a cold boot vs reset as it executes the same code?
Unread 21-02-2008, 02:55
Kevin Watson's Avatar
La Caņada High School
FRC #2429
If you zip up your code and e-mail it to me I'll have a look. If I remember correctly, I disabled the watch-dog timer in the library code so this shouldn't be a problem. I haven't reverse engineered the master processor code (yet <grin>), so I don't know if it's enforcing some kind of initialization time limit. For grins you could try commenting out the memory clearing code in _startup and see if that makes a difference.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-02-2008, 09:57
I'll try that first, and if the results aren't what I expect, send you a copy. Thanks for all the help.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
4 pin EDU PWM out power, red pin2 V in error Dale(294engr] Electrical 4 13-02-2004 03:03
power supply of control system archiver 2000 5 24-06-2002 00:14
Control System Power Al Skierkiewicz Technical Discussion 0 25-03-2002 09:04
