Go to Post Sometimes i wish the robot could fit into my pocket. - GMAdan [more]
Unread 18-02-2008, 21:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: CIM Motor Data Sheet/Operating Temperature
Originally Posted by Swttrt224 View Post
Our cim motors are getting very hot after a few practice runs.
Does anybody know where we can get the specs on this year's cims?
Does anybody know what the maximum operating temperature for them is?
How dangerous is it if we do overheat them?
The CIM motor data from 2005 is here.
Note that the normal load specified for this motor is 64 oz-in torque, and the specified current draw at that load is 27 Ampere. Note also the endurance test conditions specified (under the heading Special Features near the bottom right of the drawing):
Originally Posted by CIM Motor Specifications
1) DUTY CYCLE:INTERMITTENT, CCW 3 MINUTES ON 2 SECOND CW 3 MINUTES ON 30 MINUTES @64.0 OZ-IN,
2) LIFE:1000 CYCLES MINIMUM
So the CIM's manufacturers indicate that motors of this design were tested by running the following load cycle:
1) Apply +12V between the red and black leads and load the shaft at 64 oz-in for three minutes,
2) Remove the voltage for two seconds,
3) Apply -12V between the red and black leads and load the shaft at 64 oz-in for three minutes,
4) Remove the voltage for 30 minutes,
and then repeat steps 1 thru 4 until 1000 cycles are complete.
My understanding is that the CIM was developed as a winch motor. In that application it is often operated intermittently beyond its normal load.
Richard Wallace
since 2003
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
Accelerometer data sheet Joe Ross Electrical 16 19-01-2005 12:26
HTML version of motor data sheet from FIRST manual Roland Motors 0 14-01-2005 22:13
Here's Ed's 2nd Annual Data Sheet ...... Ed Sparks Championship Event 11 21-04-2002 21:15
