Go to Post The greatest lesson we can teach our kids is how to win. - AdamHeard [more]
Unread 18-02-2008, 23:27
MrExploiter MrExploiter is offline
FRC #1255
MrExploiter is an unknown quantity at this point
Desperate need of help
Hello everyone, our team is in some desperate need of help, as previously stated. I'm not sure what happened, but we didn't get our new MPLab from Micro, so we're running into a big snag in the completion of our robot. Our team has just been running off of default code, due to the lack of a programmer (Quit earlier in the year). Does anyone have any suggestions on acquiring a copy of the MPLab or a complier so that one can program the robot?
Unread 18-02-2008, 23:32
MR T 1923's Avatar
MR T 1923 MR T 1923 is offline
Strongest Physics Teacher on Earth
AKA: Rich/Mr. T
no team (big mike)
MR T 1923 has a spectacular aura aboutMR T 1923 has a spectacular aura about
Re: Desperate need of help
http://www.download.com/3120-20_4-0....&fileSize=&ca=
these are all "free" I hope this helps. I don't have much to do with programming as I left that to my students.
I do in fact Pity the fool
Unread 18-02-2008, 23:37
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Easy C Trial: http://www.intelitekdownloads.com/easyCPRO/
Highly suggest EasyC at this point if you are new at programming. . . MPLab might just confuse you more this late at night
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 18-02-2008, 23:38
FRC #1255
Thanks for the timely response, I'll try it out. I'm not even a programmer, but I have got to do all I can for my team. While, I test this out, anyone else know of any other programs?
Unread 18-02-2008, 23:41
FRC #1255
Actually, I know Java, and they're really simmillar. I've already got a code, that was put together that might work, so I was in need of a compiler for it. I don't like EasyC to much, I really haven't been able to figure out the needed input for varibles after you drag and drop them.
Unread 20-02-2008, 22:15
Loubear's Avatar
Loubear Loubear is offline
AKA: YLou
FRC #0075 (RoboRaiders)
Loubear will become famous soon enoughLoubear will become famous soon enough
Just to put my 2 cents in, all you really need is mplab and possibly labview for testing. Labvew is included with the kit of parts, and since you already know Java, just imagine C as Java w/o access levels, classes, and all that object oriented stuff... and has pointers. Java was made so that C/C++ programmers could pick up on it easily, so it works both ways.
Unread 20-02-2008, 22:43
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
MPLab as well as the C18 Compiler (Student Edition) are available for free from Microchip. Those two together, with Kevin's Framework, and the fix-it windows should be enough to program your robot.
Unread 25-02-2008, 21:20
FRC #1255
Do you think you can give me a link to that please? I can't seem to find it on their webpage. Thanks in advance.
Unread 25-02-2008, 22:28
MPLab: http://microchip.com/stellent/idcplg...&part=SW007002
C18: http://microchip.com/stellent/idcplg...&part=SW006011
Kevin's Code: http://www.kevin.org/frc/
Unread 25-02-2008, 22:38
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Definitely watch your variable types, though. I'm a Java programmer, and the most confusing thing about C for me was when I found out that you need to cast unsigned variables to signed types before making them negative. I could never figure out why the computer would do these crazy things until I added a printf and found that the variables were wrapping around to the highest value.
Desperate for help in camera tracking itsme Programming 9 06-02-2007 15:55
I am in desperate need of seat motors Gusman1188 Motors 2 04-03-2004 13:14
In desperate need of some help archiver 2000 0 23-06-2002 23:40
desperate help Andrew Dahl General Forum 0 21-11-2001 12:08
I'm desperate... Carolyn Duncan Technical Discussion 33 04-08-2001 23:46
