Go to Post This is the type of thing that puts an evil glint in Dave's eye and a smile on his face... - Wetzel [more]
View Poll Results: do you think they are unreliable
yes 20 66.67%
no 10 33.33%
Voters: 30. You may not vote on this poll
Unread 19-02-2008, 01:10
647techangel's Avatar
647techangel 647techangel is offline
K.I.S.S (Keep It Simple Stupid!!)
AKA: Tech_Angel
FRC #0647 (Cyber Wolf Corps)
Team Role: Driver
647techangel has a spectacular aura about647techangel has a spectacular aura about
Who thinks the IR board's operational characteristics leave much to be desired?
in other words it vehemently inhales
Unread 19-02-2008, 01:13
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Re: WHO THINKS THE IR BOARDS ...OPERATIONAL CHARACTERISTICS LEAVE MUST TO BE DESIRED
I would like it to have a diode but otherwise i like the idea
Unread 19-02-2008, 01:29
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
i could prolly build a better one myself......
Unread 19-02-2008, 01:32
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Although it is a new idea, it's VERY unreliable. I think it gets to the point that they might as well have not given it to us and let us do fully autonomous robots. It just makes the job for us programmers a LOT more complicated.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 19-02-2008, 03:14
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
The IR board is pretty reliable by my standards.
It survived a direct short from an energized frame(reminder, ALWAYS triple check how taped your batteries are) through the board, while only destrying 3 traces, that were easily (with a fine soldering tip and tiny wire) fixed.
It lives, and the hybrid code runs excellently. The range on the recciver is very nice when your remote uses full batteries, and it lived.
Unread 19-02-2008, 10:30
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We have found it reliable, and the support from the desgner outstanding.
I don't understand the complaints about durability when subjected to reverse-voltage. Try wiring a Victor incorrectly... (I've seen FETs explode!)
Unread 19-02-2008, 12:53
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Who thinks the IR board's operational characteristics leave much to be desired?
The biggest problem it has is not getting around IR interference - other remotes can make it unresponsive to your remote. While this is clearly something you'd want them to solve, it does bring up some pretty important real life considerations. When dealing with something like the Mars Rover, NASA fully expected to have continuous contact with it, but they couldn't plan on it. So they have to have a certain amount of autonomy built in in case something goes wrong with the communications. If, for example, the rover landed and broke it's modem, NASA couldn't have communicated at all. But the rover could still go around and collect data and store it internally, which NASA could retrieve at a later time. Another great example might be a remote deep see submersible. These are things that are generally controlled from a joystick on a boat, but do have certain programming if the communications drops - like return to the surface.
Regardless, when dealing with remote systems you ALWAYS have to plan for the probability of your communications dropping out at some point. In that regard, the IR boards are perfect for use in the competition.
Unread 25-02-2008, 22:39
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by eagle33199 View Post
When dealing with something like the Mars Rover, NASA fully expected to have continuous contact with it, but they couldn't plan on it...
No, not really. We knew that, at best, we would be able to converse with each rover twice a day and somtimes we wouldn't be able to converse for over a day. BTW, my wife lead the telecom team in flight operations for a few years.
Nope. The autonomous mobility software wasn't uploaded until after each rover landed (The first cut was still being worked on after they launched). Furthermore, there is no provision for either of them to go site seeing without permission from Earth .
-Kevin
Kevin Watson
http://kevin.org
Unread 25-02-2008, 22:49
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
We have found our IR very reliable, once we got the remote we had programmed to a different setting(before we were having problems programming one button, less likely four, then once solved that problem we had no problem programming the IR and using it, it has good range and everything
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 26-02-2008, 00:05
AKA: Dr. Brooks
no team (WRRF)
The IR board, like every thing else, is part of the game challenge. If you reverse the power it fries like a few other IFI parts. Avoiding this by being careful, or modifying the board with a diode, is up to you.
The "brown out" problem is one of those unpredictable unfortunate things, leading to more game challenge that we counted on, but it is still quite surmountable. We will try Kevin's brownout fix as soon as we get access to the robot again.
I would like to suggest that those teams who have succeeded in reloading the IR board code show up at your event with a sign that reads "IR boards reloaded here." We will be at Portland, and San Jose with our PIC programmer. Make sure that you bring the standard hex file and the one modified according to Kevin's directions. The other teams counting on their IR boards will appreciate it.
Eugene
Unread 26-02-2008, 01:14
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Our IR board stopped working shortly after being mounted on our robot. I figured it was having the brown-out problem so we tried to reprogram it with no success. Reading the device revealled a bunch of emptyness. Then I checked the regulator and it was outputting 6 volts. I don't know if that wrecked the PIC or not, but it wouldn't work. The team decided that the IR isn't worth the effort due to the high probability of IR interference during the matches. We are going with an alternative means of communication.
Unread 26-02-2008, 01:35
dtengineering's Avatar
AKA: Jason Brett
If you don't like the IR board, don't use it.
We have been using a PIC16f627a with a PNA4602M IR receiver and about six lines of Pic Basic Pro code to decipher the Sony IR protocol for the past seven years as part of a mini-sumo robotics project. There is absolutely NO magic in reading an IR remote control signal... this board just makes it easier. At least until you hook up the power supply backwards.
It's a bit more of a challenge to program the IR routine in C than Basic, but there is no reason you couldn't just hook the Vishay sensor (or a PNA4602M) up directly to a digital I/O port on the RC and write your own code to decipher the signal.
And if you have a specific suggestion on how the board can be improved (yes! the diode would be a great improvement!) then make the suggestion.
Jason
Unread 19-02-2008, 14:59
Racer26 Racer26 is offline
My beef with the reverse voltage thing is that 1) a simple diode would have solved the problem, where this is more complicated with the victors, after all, they handle alot more power. and 2) the supplied ribbon cable has a BLACK wire connected to the positive pins, and a GREY wire connected to the negative pins. Needless to say this would be confusing to many teams (including my own), especially those with an electrical team thats learning.
Unread 19-02-2008, 16:06
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
Ours worked for Twice. Our robot has no shorts, no current through the frame, and no shock to the board. It fried. There are no exact replacements though you can buy an equivelent for around 30 bucks. The only explanation for there spontaneous breakdowns given buy the designer was something that couldve been simply fixed by adding a few components before shipping them out to the teams. I have made equivelent boards and they've never broken down. unfourtunately they r built in to several projects that would be destroyed if i removed them so i guess were going to have to go with the KOP one.
First one to reply gets a cookie!!!
Unread 20-02-2008, 16:35
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Please don't say there is no other explanation. Unless you were actually wearing static wrist straps and practice proper ESD control there is no way you can blame this entirely on the design. The amount of static that is needed to damage a component actually falls under the value needed to perceive such a shock.
who thinks this years competion is easy jedilearner General Forum 25 11-01-2004 00:55
who thinks that 74,68,9 were a good alliance 18voltMilwauke Championship Event 2 29-04-2003 11:46
how much is too much on the DRILL MOTORS? archiver 2001 11 23-06-2002 23:53
