Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 18-02-2008, 05:09
ericsundbergva ericsundbergva is offline
FRC #1541
ericsundbergva is an unknown quantity at this point
Question Lap counter, What port? Mounting Rule 18
The rules say to wire a male PWM plus within 4 inches of the flag pole mount and wire to an analog or digital controller port.
1. Which port works with the default software
2. The rule R18 diagram is unclear. It appears to be a view looking down on the bot with the clear area to the rear, but the lap indiactor needs an upward view. Perhaps that radius area needs to be 360 and provides a cone of vision of 45 degrees up?
COMMENT a male plug hanging lose risks being shorted. They should have made it female!
Unread 18-02-2008, 05:33
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Lap counter, What port? Mounting Rule 18
Any port will do. The point of this wire is simply to provide power to the lap indicator.
Yes, the male end does risk shorting, and a female end would not. However, since the RC has male outputs, this enables teams to just run a pwm cable up to the flag holder, rather than forcing them to make a female-female cable.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 18-02-2008, 06:11
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
I am not sure where the electrical team came up with it, but we have a PWM with a shielded male end that sort of looks like a female end. The shield provides protection for both shorting and damagining the pins.
Unread 18-02-2008, 08:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Those hooded connectors are used in R/C stuff like airplanes and cars.
Unread 18-02-2008, 08:52
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
the open radius needs to be 180 degrees i believe and you need a male PWM connector within 4 inches of the flag mount.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 18-02-2008, 11:24
Trav-O's Avatar
Trav-O Trav-O is offline
THE PROGRAMINATOR
AKA: Travis
FRC #0510 (Hawaii 5-1-0)
Team Role: Tactician
Trav-O is infamous around these partsTrav-O is infamous around these parts
so it doesnt matter if connect the pwm to a digital in/out that we have set to "off"
(ie. rcdig_in_01 = 0; could we use digital input 01 as a pwm port to power the lap counter)
Be safe!!! OR YOU MIGHT GET INJURIES!
Unread 18-02-2008, 11:34
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
yup...
digital pins should have a +5, GND and logic line. All of the +5s are connected, all of the GNDs are connected. You have software control over the signal port only.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
REVving up for a new season
FRC #2848 (All-sparks)
sure you could set it to a Digital in/out that is off (although the pins are always powered) but I guess you won't want your points for lapping. I am sure the other alliance would have no problems with you doing this.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 18-02-2008, 16:49
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Team 40 went to Suffield to test our 08 robot this weekend and the Signal wire is not even connected. The Flag basically has a little clear plastic box with a circuit inside connected to the flag pole. The circuit gives the robot zero feedback, it just leaches 5v power from the RC. I hope FIRST has implemented protection for teams that accidentally hook up the flag power to the 7.2v PWM lines.
Unread 18-02-2008, 16:52
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
What are you talking about? As you note, the I/O pins are always powered, so it doesn't matter what's going on in software.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-02-2008, 05:44
FRC #1541
To clarify, I presume the lap indicator has some way to identify the robot and is not just a LED.
So does it have an integral data signature being sent out, (The Judges provide so this may be it) or is it in the bot software????
Eric
Unread 19-02-2008, 08:22
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Eric
I don't think this is a matter to be concerned about. They told us its operation would be verified before the start of the match, so we're fine.
Nothing is in the bot software. This lap counter pulls 5v from the RC, nothing more. Your code has absolutely no influence over what the lap counter does, unless you mis-wire it--it connects to the red wire (5v) and the black wire (GND), neither of which your code has control over.
JBot
Aren't signatures a bit outdated?
Lap Indicator Rule <R18> Clarification t-raum General Forum 1 28-01-2008 11:04
Lap Counter??? RoboGeek99 Technical Discussion 3 25-01-2008 19:33
So uh yeah... How 'bout that lap counter? Also Metallica. Tach'ko Electrical 11 21-01-2008 12:01
Lap counted when lap indicator crosses line? Madison Technical Discussion 6 08-01-2008 09:15
pic: IR Lap Counter on the Manchester Kickoff Field ahecht Extra Discussion 13 06-01-2008 21:38
