Go to Post I think I need a bigger cup of coffee.... - JaneYoung [more]
Unread 19-02-2008, 08:39
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
pic: Tigertrons 222 2008
Unread 19-02-2008, 08:47
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Re: pic: Tigertrons 222 2008
Now for the specs. and some video....
2 speed ball lock ~8fps and 12fps
can hurdle and place very similar ChiefDelphi 47
it can break the 80" rule, but not while in normal operation.
we weighed in at 109.5lbs and for the first time ever there are no speed holes
IR sensors to tell us when to pick up the ball
Now for the video....http://www.youtube.com/watch?v=_cshml0GNPQ
The video is with a dead battery and right before crating, but you get the idea. we couldn't show a real hurdle because of the ceilings.
Anyway 222 is all geared up for Overdrive! Good luck to all teams. You can see us in action at Pittsburgh.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Looks like a typical powerhouse Tigertrons machine!
Great job. Looking forward to seeing it take the Track!
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
Unread 19-02-2008, 08:51
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Neat machine! But, as always, I have questions...
-Have you tested your IR sensor with both Red and Blue trackballs? Spotted red/blue trackballs? A dirty/scuffed ball? (just saying because we were using an IR then realiazed how variable the readings were)
-How'd you guys bend your pipes with a curve like that?
Nice!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 19-02-2008, 08:59
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Woohoo! I look forward to seeing 222 every year and it's no wonder why. Congrats on your design and effort!
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 19-02-2008, 09:03
AKA: Cliff Mock
Nice!
-q
Thanks......we haven't tested our sensor with a blue ball, however it works well with our red ball and other objects that pass in front of it. We did notice variable readings over longer run times and are going to be keeping a close eye on things.
The top pipes were bent using (for lack of better terms) a large sheet metal roller. They were bent to the same radius as the ball. The bottom grippers were bent with a bunch of patience, and small bends on a hydraulic bender, but we have also bent similar things on a manual bender.
Unread 07-03-2008, 09:58
AKA: Cliff Mock
Some things I forgot and some things thanks to the fix-it windows.
Things I forgot: Encoders in the transmissions for hybrid mode should allows us to do a lap on an open field after some tweaking. We roll on two 6"x1" IFI traction wheels and two AndyMark 6" aluminum onmi wheels. Wheels can be changed out in a matter of 2 minutes if we have any problems.
Things thanks to the fix-it window: a lower first gear set in case teams start getting more defensive
Good luck to everyone! We can't wait for Pittsburgh!
Unread 11-04-2008, 09:41
AKA: Cliff Mock
Anyone in Atlanta looking for new frame materials next year be sure to stop by and check our robot. I'm sure our students will be more then happy to tell you about their building experience with 80/20 Quick Frame.
pic: 222 Tigertrons 06 Teaser team222badbrad Robot Showcase 14 13-02-2006 20:35
pic: Tigertrons 222 05 Pic #2 team222badbrad Robot Showcase 4 01-03-2005 08:25
pic: 222 TIGERTRONS TEASER team222badbrad Extra Discussion 16 22-02-2005 19:39
pic: Tigertrons 222 Memorial Day Parade CD47-Bot Extra Discussion 11 17-06-2004 14:51
Image Discuss: Team #222 - Tigertrons CD47-Bot Robot Showcase 1 24-02-2003 11:17
