Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:23
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Using White Paper Code & Comments
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/16/2000 7:42 AM MST
In Reply to: Here's a theory.... posted by Mike Gray on 3/16/2000 7:27 AM MST:
: I see that you filter p1_y. Are you using my code from the Innovation First white paper page? Do you find that it improves your motion control, or is it detrimental?
I'm using the code from the white paper, and running both our x and y axes for port 1 through it. Seems to help, however, since we were more interested in keeping it running during EMU, I didn't have much of an opportunity to adjust the coefficients. That's going to be one of my tasks in Chicago, and I have also implemented 75% scaling down on our x-axis, to allow for more control when steering. Keep an eye on us in Chicago to find out if it all works together OK...
[IMG] code is Off
Battlebots I.Q.- A serious threat to FIRST or a half thought up cheep copy? Joe Matt General Forum 75 17-10-2005 20:43
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
robot control emulator for default or other program CharlieWilken Programming 26 24-02-2002 02:36
control program looping??? ctartist236 Programming 1 08-02-2002 10:09
