Go to Post When I first read this comic, I thought "Awww, how cute!". But then, thoughts of Karthik singing J. Lo's "Love Don't Cost a Thing" started running around through my head, and everything changed. - Travis Hoffman [more]
Unread 19-02-2008, 09:34
mta mta is offline
FRC #1896
mta has a little shameless behaviour in the past
Smile IR board unlocked. Getting it to work.
Team 1896 had a rough start when it came to the IR board, but we finally figured it out. So, we decided to be nice and share our findings.
Here is how we did it:
The IR board itself is powerd from a standard DC 9-volt battery on pins 1 and 3. 2 and 4 are unused but you COULD use them to further secure your connections. Pins 1 and 2 are for positive battery input, while 3 and 4 are for negative battery input.
Then we ran the white(signal) cables from 4 PWM wires to pins 5-8 on the IR board, These carry the actual signal from the board.
The 4 leftover black and red cables of the PWMs that are connected to the Ir signal pins were ran together with there respective color. All 4 red wires ran to one single RED wire, and all 4 black wires ran to one single BLACK wire...
These RED and BLACK wires were then ran to the black and red wires of another PWM and that PWM was ran to a PWM output on the IFI board.
This output can then be set to 255 to make the IR board signal pins act as normally open switchs that are connected to digital inputs.
If you have any questions please feel free to ask.
~Justin
from team 1896
Motivating quote of the day:
A civilization is built on what is required of men, not on that which
is provided for them.
-Saint-Exupery, Antoine De
Unread 19-02-2008, 13:37
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: IR board unlocked. Getting it to work.
Don't you mean the "pwm" cables were connected to digital inputs on the robot controller?
Brian
Brian K
Team 1225 Robotics Mentor
Unread 19-02-2008, 13:46
mta mta is offline
FRC #1896
Brian
The PWMs go from the IR boards pins to the digital inputs... and also from the PWM outputs to the digital inputs.
White cables come from the IR board....the red and black ones come from the PWM outputs.
Unread 19-02-2008, 13:49
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
That seems like an odd configuration... Why did you do it this way? I'm don't follow where you connected the red wires and black PWM cable wires on the IR board. Did you also connect both Red and Black wires to a single PWM output on the RC?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 19-02-2008, 16:04
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Just a reminder... while this is fine for testing, it is not legal during the competition. Everything must be powered from either the main 12v battery, or from the backup battery (via either a PWM or analog/digital i/o port).
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Getting constant motor power with IR board Nightfall831 Programming 16 15-01-2008 11:20
Getting the camera to work in autonomous dpick1055 Programming 8 10-02-2007 20:57
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
