Go to Post Moral of the story: Keep something you can power on gamepieces at all times. Leaving them "to do their own thing" will only lead to heartbreak. - Ian Curtis [more]
Unread 19-02-2008, 12:19
saihla saihla is offline
FRC #2367
saihla is an unknown quantity at this point
Help!!! Bill of Materials...
Completely missed the fact that we needed a B.O.M.!!! Everything we have on the bot is FIRST approved in the manual, but not recorded. How precise do they really need it? They want weights and prices of individual parts...? Do we need to record the parts that they sent us? What about parts that were donated, can we record the price as zero? Is there actually a chance of disqualification here if we make errors or does it just make the judges' jobs a bit harder?
Unread 19-02-2008, 12:22
FRC #2367
Re: Help!!! Bill of Materials...
And... do we need to know precisely how many small things [nuts, screws...] that we used, or can we estimate?
Unread 19-02-2008, 12:33
Best Available Data
FRC #1778 (Chill Out!)
First off, I'd check Section 8 "The Robot" of the manual. FIRST's rules regarding the BOM can be found there. I wouldn't worry too much about precision. The cost can only be for the smallest commercially available piece. For example, if I use a square foot of Lexan, but Lexan only comes in 4x8 sheets, I have to record the price of the whole sheet. Do the best that you can, and it won't be a problem. Since you probably can't estimate how many feet of stock you used, I'd look up the prices, so you can quickly calculate the costs on Thursday. Other things though you can probably do now.
Unread 19-02-2008, 14:35
FRC #2367
Do we need to include the peices from the Kit of Parts?
Unread 19-02-2008, 14:36
I would, but put "KOP" instead of a cost.
Unread 19-02-2008, 15:51
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I don't believe you need to include anything from the kop; we as a team have never done so. The weights are not required only reccomended for your own weight tracking purposes.
Unread 19-02-2008, 16:56
FRC #2367
THANK YOU SO MUCH!!! Saved us a ton of time right there. Quick question - is electrical tape allowed for non-electric purposes? We're using a bit to secure our claw...
Unread 19-02-2008, 17:03
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Tape (of any kind (except velcro tape or sticky foam)) is not allowed to be used to attach components to the robot. Here's the relevant rule:
<R38> Adhesive backed tapes shall not be used as a structural fastener, or to connect two or more parts together. Adhesive backed tapes may only be used as follows:
  • Textured or coated tapes may be used to provide an alternate surface finish or treatment to a portion of the ROBOT.
  • Velcro tape, any hook and loop tape or double-sided sticky foam may be used for attaching components to the ROBOT.
  • Reflective tape may be used with optical sensors in small amounts.
  • Adhesive backed tape and labels may be used for labeling purposes on wires, cables, pneumatic lines, etc.
  • Electrical tape may be used as an electrical insulator.
Last edited by vhcook : 19-02-2008 at 17:04. Reason: overgeneralized a bit the first try
Bill Of Materials Form orelinde General Forum 12 26-02-2007 13:51
Bill of Materials, what goes in it? Matt Krass Rules/Strategy 2 15-03-2005 19:49
Bill Of Materials - Format Question Kates General Forum 1 20-02-2005 20:04
Bill of Materials Jeremy General Forum 1 07-01-2004 01:41
Where is the Bill of Materials? mnkysp6353 General Forum 4 24-12-2001 17:39
