Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 19-02-2008, 14:55
kDude kDude is offline
FRC #2450 (RaiderBots)
kDude is an unknown quantity at this point
autonomous mode
Question, do we need the IR board/sensor to initiate autonomous mode at the beginning of the round? I've heard that officials change all the robots to autonomous mode when the round starts automatically.
Unread 19-02-2008, 14:56
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: autonomous mode
you don't need it unless you programmed your auto to start with the ir, other than that, put it in the right spot in the code, and first will do the rest!!
Unread 19-02-2008, 14:58
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Re: autonomous mode
No you do not need to have the IR decoder board. The officials start autonomous through the radio.
Unread 19-02-2008, 15:02
Re: autonomous mode
Sweet, thanks. Now if only we had our robot...
Unread 19-02-2008, 15:26
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
Re: autonomous mode
Whether or not you programmed it to " start with autonomous" the autonomous routine will still start and run without the IR Board.
Autonomous Mode fallen751 Programming 14 09-02-2007 00:28
Autonomous mode HellBoy Programming 4 07-02-2007 18:22
Autonomous mode chs938 Programming 1 03-02-2006 10:19
Autonomous Mode David Bryan Programming 1 21-01-2003 21:15
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
