Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
  #91   Spotlight this post!
Unread 16-01-2008, 12:54
Re: Beware of R16 your robot design may be too big.
Originally Posted by wilsonmw04 View Post
The way i understand the rule is as follows and this the way i explained it to the team: If you were to place a 80" diameter coke can, with the bottom removed, over the robot, would the can sit entirely on the ground ground or would part of it sit on your robot. If it sits on the robot, then we are breaking the size rule. The thumbnail is question would only be legal if it was oriented so that it's largest length was 80" and no other part of the robot was outside of the cylinder.
You do know that the cylinder reference is a reference only, right? Yeah, it works, but the rule is 80" point to point. Easy test: Two posts, set 80" apart. Put robot between in all possible orientations that come close (e.g. arm out). If any can't fit, they need to be hard-stopped or programmed out.
  #92   Spotlight this post!
Unread 16-01-2008, 12:59
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Originally Posted by ALIBI View Post
EDIT: My analysis assumes that the cylinder is 80" since that is the way most of the references to R16 have been in CD, that the robot must fit inside an 80" cylinder.
Please take a look at the FIRST Q&A, especially this thread: http://forums.usfirst.org/showthread.php?t=8159
There is no "80 inch cylinder" rule. That was just an EXAMPLE of one shape that will pass.
The rule can be rephrased as this: if you were to project all points of the robot onto the ground (i.e. a horizontal plane), would there exist any two points which are more than 80 inches apart? If the answer is yes, then the robot is too big.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
  #93   Spotlight this post!
Unread 16-01-2008, 13:06
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
I AM SO WRONG! The diagram a few post up really messed with my brain. Either the 80" coke can or a 160" coke can with the center on any part of the robot do the same thing. The kids have a design that fits within the 80 inches, it would just be a little bit better if they could get another couple inches. There are plenty of suggested ways to maximize the 80", I am not looking for any more in response to this post. Thank You.
EDIT: Responce to ay2B, previous post, I was posting this while you were also posting, I have been there and done that, many, many times, my head officially hurts.
  #94   Spotlight this post!
Unread 16-01-2008, 13:10
AdamHeard's Avatar
Lead Mentor
This is the most clear way I have heard it stated.... Any two points more than 80" apart? if so, fail (restating that was more for my own understanding than anything).
  #95   Spotlight this post!
Unread 16-01-2008, 14:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Adam, the rule says "While in the PLAYING CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80 inches"
I think that the best way to say that is just like you said it: There cannot be any two points on the robot that are more than 80" apart (in a horizontal plane)
Here is a better drawing of a robot that is illegal, even though the arm extends less than 80" from the rear bumper measured straight on (and I apologize to you ALIBI for messing with your brain!)
  #96   Spotlight this post!
Unread 16-01-2008, 14:46
ALIBI's Avatar
FRC #0141
Team Role: Parent
I like this drawing a whole lot better. Aside from design changes, there just does not appear to to be any way to make 80 inches any longer than 80 inches. Did I just say that? What if we measured with nautical miles, oops, that would make it worse.
EDIT: Thank you Squirrel, but it was probably more my doing than yours..
  #97   Spotlight this post!
Unread 17-01-2008, 15:25
GaryVoshol's Avatar
Cogito ergo arbitro
See Q&A: http://forums.usfirst.org/showthread.php?t=8181
A robot that is physically capable of extending past 80" but does not do so during a match will not be penalized.
(since 2004)
  #98   Spotlight this post!
Unread 17-01-2008, 15:47
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Originally Posted by Kat Kononov View Post
So, bumpers do count as part of the robot in <R16>. But, consider the fact that bumpers are only about 3in thick, and that you only need 2/3 of the robot covered with bumpers. Then, if you have a 38x28 robot, you can leave the back of the robot without bumpers, and thus only gain 3in in the front, not a whole 6in.
yes but you would want to cover the back of your robot especially well since you will be getting "gently bumped" quite a bit there.
-vivek
"we don't build robots, we build people"
  #99   Spotlight this post!
Unread 17-01-2008, 16:02
israel199308 israel199308 is offline
FRC #0354
israel199308 is an unknown quantity at this point
What do you mean by "If you are planning to reach over the overpass while hurdling you better either start while underneath or not reach more than 3" past it. That includes your gripper."
  #100   Spotlight this post!
Unread 17-01-2008, 16:41
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
ALIBI stated "does not appear to to be any way to make 80 inches any longer than 80 inches."
Now if you just accelerate your robot to near the speed of light whilst measuring it in the earth's inertial frame...
  #101   Spotlight this post!
Unread 17-01-2008, 20:44
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
But apparently any robot that is just sitting still is now formally moving at the speed of light, so that should be pretty easy.
  #102   Spotlight this post!
Unread 19-02-2008, 15:58
Originally Posted by troy27 View Post
What a what's up with the dynamite=pig????
is the pig going to explode
Oink...Oink...BOOM! The team name is Exploding Bacon. One of last year's Einstein semifinalists.
  #103   Spotlight this post!
Unread 20-02-2008, 13:32
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Cool Re: Beware of R16 your robot design may be too big.
I Wonder How many teams have really missed this Rule and will FIRST inforce it?
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
  #104   Spotlight this post!
Unread 20-02-2008, 13:37
GaryVoshol's Avatar
Cogito ergo arbitro
I'm sure it will be enforced - there's a notation on the inspection sheet to indicate whether or not the robot can physically extend greater than 80".
(since 2004)
  #105   Spotlight this post!
Unread 20-02-2008, 13:38
Billfred's Avatar
Billfred Billfred is offline
I Wonder How many teams have really missed this Rule...
I imagine it's a non-zero number.
Absolutely.
What's your robot design? NeoRyu777 General Forum 19 10-02-2006 17:51
So your original robot design was..... LightWaves1636 General Forum 23 05-02-2006 03:36
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Beware of spending too much time in Chief Delphi Forum! Ken Leung Rumor Mill 42 21-05-2003 18:22
Size of the field: too big? too small? archiver 2000 5 23-06-2002 22:44
