Go to Post This is high school robotics for fun and education. Let's try and keep it that way. - Rod [more]
Unread 19-02-2008, 16:04
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: IR board unlocked. Getting it to work.
Originally Posted by mta View Post
The IR board itself is powerd from a standard DC 9-volt battery on pins 1 and 3.
Just a reminder... while this is fine for testing, it is not legal during the competition. Everything must be powered from either the main 12v battery, or from the backup battery (via either a PWM or analog/digital i/o port).
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Getting constant motor power with IR board Nightfall831 Programming 16 15-01-2008 11:20
Getting the camera to work in autonomous dpick1055 Programming 8 10-02-2007 20:57
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
