Go to Post My wife got mad at me when I told her I wanted to name our daughter Lotus. "What you mean the software?" she squawked. "No I mean the flower." I said. geeks, I swear.... - Koko Ed [more]
Unread 18-02-2008, 11:42
Trav-O's Avatar
Trav-O Trav-O is offline
THE PROGRAMINATOR
AKA: Travis
FRC #0510 (Hawaii 5-1-0)
Team Role: Tactician
Trav-O is infamous around these partsTrav-O is infamous around these parts
Powering IR Board by PWM
Ok, so there's several ways to power IR boards:
backup battery
12volt circuit breaker block
pwms in digital inputs or analog inputs
so here's my question
if we want to power the board via pwm, which color pwm wires link to the V+ and ground of the ir board.
It seems like it would be black to ground and red to V+, but I don't want to accidentally fry the board because I assumed. Especially because apparently the board is really sensitive to reversed polarity... (has anyone heard of diodes?)
Be safe!!! OR YOU MIGHT GET INJURIES!
Unread 18-02-2008, 11:49
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Powering IR Board by PWM
Team 40 is powering the IR board by the PWM ports, You connect the "+" to red and "-" to black, signal is unused.
Unread 18-02-2008, 14:01
Trav-O's Avatar
THE PROGRAMINATOR
AKA: Travis
Safe solution Powering IR Board by PWM
OH! well we found out that we would have to plug in the pwm after we turn the robot on. (team update 10)
problem:
the pwms are covered with lexan for protection.
we could drill a hole and feed it through everytime we turn the robot on and off, but some ignorant someone may be unaware that they just fried the board by turning the robot of befor removing some random pwm wire...
SO.... i'm ganna try this: a timed delay relay that turns on a few seconds after the robot turns on. any ideas?
***NOTE***
to send 5 volts to the red wire of a relay, you use the relay1_rev instead of the relay1_fwd
(fwd controls the white wire)
Unread 19-02-2008, 14:23
samchauuu samchauuu is offline
FRC #1626
samchauuu is an unknown quantity at this point
you can order them at this site:
http://www.globe-motors.com/distcont.html?state_code=NJ
if it doesn't work IM me using AIM my sn is samchauuu
or email me: samspotty@yahoo.com
Unread 19-02-2008, 16:11
GrammarNazi GrammarNazi is offline
FRC #2952
GrammarNazi is on a distinguished road
Send a message via AIM to GrammarNazi
You can also power them from a spike that turns on after the robot is on and the program starts... thats what i did after we fried the first one
First one to reply gets a cookie!!!
Powering the IR Board aznzricex Electrical 1 31-01-2008 11:02
Powering the IR board Dan G. Electrical 3 23-01-2008 01:58
Powering the RC Mr. Steve Control System 15 06-03-2005 23:21
powering up nick_champ_2 Electrical 2 08-02-2003 15:08
