Go to Post Doing something reliably is better than doing something well occasionally. - Andrew Schreiber [more]
Unread 18-02-2008, 15:31
Swttrt224's Avatar
Swttrt224 Swttrt224 is offline
System Integrator
AKA: Caitlin
FRC #2022 (Team IRS (IMSA Robotics Specialists))
Swttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of lightSwttrt224 is a glorious beacon of light
Send a message via AIM to Swttrt224
Exclamation CIM Motor Data Sheet/Operating Temperature
Our cim motors are getting very hot after a few practice runs.
Does anybody know where we can get the specs on this year's cims?
Does anybody know what the maximum operating temperature for them is?
How dangerous is it if we do overheat them?
$TEAM IRS #2022$
2009 Season:
MWR semi-finalists
FWR TBD
2 weeks until salvation...again
Unread 18-02-2008, 16:00
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Re: CIM Motor Data Sheet/Operating Temperature
It is normal for the CIMs to get very hot after 2 minutes (match length) of heavy use. If you are operating for longer than a match length, they will be very hot, but I've never seen a CIM quit working from getting too hot. In my experience, you can drive a robot the length of a parade route (1/2 mile and 1 battery change) with 1 CIM per drive gearbox and they'll be really hot, but that's about as much as I'd drive them without a break.
When you change your battery, it's a good idea to let your motors cool down a bit before continuing. That's my rule of thumb.
I don't have any numbers to back up the way I do things, I just try to play it safe since I don't have any official data.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 18-02-2008, 20:27
iwashere1990's Avatar
iwashere1990 iwashere1990 is offline
Team 1389's Everything
AKA: Jason
FRC #1389 (The Stig)
iwashere1990 is an unknown quantity at this point
They do get very hot in a minute, on our robots we usually put atleast one computer fan near the motors to cool them down.
Good Luck
"Achievement is not always success while reputed failure often is. It is honest endeavor, persistent effort to do the best possible under any and all circumstances."
Team Number:1389
My Job on the Team:Everything but Programing
My Rookie Year:2007
My Team's Rookie Year:2004
Awards: Zero
Number of Members: 7-9
Number of Mentors: 1 (more like zero)
Our Current Budget for the Team: -6,000$
Number of Headaches this Year: 4
Number of Colds: 1
Number of PHAILS: > 10
Unread 18-02-2008, 20:32
Aren_Hill's Avatar
Build Nifty Things
Our robot in 2006 actually managed to severely decrease the cims performance from them getting too hot. This happened after the first finals match on galileo when a piece of tread came off preventing our drivetrain from spinning, hence a toasted cim. Due to that the next match drivetrain response was ultra shotty and cost us the next match.
we actually made a rating system for that robot placing the cims as <1,2,3,4, or indefinite judged by how long you could hold your hand on it, when practicing we stopped just above 2.
Watch the heat, it cost us einstein
A guy who likes robots.
Unread 18-02-2008, 21:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
The CIM motor data from 2005 is here.
Note that the normal load specified for this motor is 64 oz-in torque, and the specified current draw at that load is 27 Ampere. Note also the endurance test conditions specified (under the heading Special Features near the bottom right of the drawing):
Originally Posted by CIM Motor Specifications
1) DUTY CYCLE:INTERMITTENT, CCW 3 MINUTES ON 2 SECOND CW 3 MINUTES ON 30 MINUTES @64.0 OZ-IN,
2) LIFE:1000 CYCLES MINIMUM
So the CIM's manufacturers indicate that motors of this design were tested by running the following load cycle:
1) Apply +12V between the red and black leads and load the shaft at 64 oz-in for three minutes,
2) Remove the voltage for two seconds,
3) Apply -12V between the red and black leads and load the shaft at 64 oz-in for three minutes,
4) Remove the voltage for 30 minutes,
and then repeat steps 1 thru 4 until 1000 cycles are complete.
My understanding is that the CIM was developed as a winch motor. In that application it is often operated intermittently beyond its normal load.
Richard Wallace
since 2003
Unread 19-02-2008, 16:14
Swttrt224's Avatar
System Integrator
AKA: Caitlin
Thanks to everybody who responded. We actually fixed this problem and another issue we were having with base control by just changing our driving gear ratios. After a few runs they still get warm, but the difference is significantly better.
$TEAM IRS #2022$
2009 Season:
MWR semi-finalists
FWR TBD
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
Accelerometer data sheet Joe Ross Electrical 16 19-01-2005 12:26
HTML version of motor data sheet from FIRST manual Roland Motors 0 14-01-2005 22:13
Here's Ed's 2nd Annual Data Sheet ...... Ed Sparks Championship Event 11 21-04-2002 21:15
