Go to Post I keep on accidently seeing (and pronouncing) it as Chef Deli. - JJG13 [more]
Unread 18-02-2008, 20:03
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
"Code Error" with RegisterRepeatingTimer
We have tried using the sample code provided here (replacing the IFI Vex headers with FRC controller headers).
However, this code triggers a code error on our RC.
Basically, the printf("_____________________\r\r"); line executes several times, then is interrupted for 3-5 seconds, then repeats, and IR input does nothing at all. After a few repetitions, the CODE ERROR light comes on. (This is all in autonomous mode).
After commenting out EVERYTHING inside the CheckIR function (leaving only void CheckIR(void) { } ), and commenting out the IR processing code (but leaving printf("_____________________\r\r"); inside the while loop) ), this problem still happens.
We are using the latest version of WPILib on a 2008 RC. Also, there are no compile-time warnings or errors.
Unread 19-02-2008, 02:48
AKA: Brad
#0190 ( Gompei and the Herd)
Re: "Code Error" with RegisterRepeatingTimer
You don't want to be printing from within the CheckIR function. Since that is an interrupt service routine, there might be problems doing long operations like that. I could imagine printing causing the code error to occur. Otherwise, I'm not sure what is going on without more information.
Also, there were a few problems with the whole program that some people were able to find and correct so be sure to read all the comments in the thread.
Brad Miller
Robotics Resource Center
Unread 19-02-2008, 16:48
FRC #4454
This is how our program looks:
#include "BuiltIns.h"
#include "API.h"
#include "ifi_aliases.h"
#include "user_defs.h"
#include <p18cxxx.h>
void CheckIR(void)
// empty
void main(void)
RegisterRepeatingTimer(30, CheckIR);
while(1)
printf("TestRun\r\r");
As far as I know, the printf function isn't being called within the CheckIR loop. The printf output comes in "bursts," and the RC locks up after a few loops.
I am aware of those corrections; however, those don't seem to be related to our problem.
Thank you.
Unread 22-02-2008, 13:38
FRC #4454
I have partially resolved this problem. It only happens when "Code Model" under "Memory Model" under MPLAB C18 compiler options is set to "Large Code Model (>64K)".
Is this expected behavior?
Unread 27-02-2008, 21:51
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
This sounds very familiar. We were having repeated problems (I don't recall the specifics now) using the Camera-related functions in WPILIB. After lots of frustration, we tried switching the memory model from large to small. Doing so suddenly resolved the problems we were having!
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
Screenshot of "code not understood" or similar error needed! Elgin Clock Programming 3 17-02-2006 22:06
Code Errors With "Bells and Whistles" Ryan O Programming 2 31-01-2006 19:29
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
How "bad" are motors with "bad" stickers? cooknl Kit & Additional Hardware 20 12-01-2005 10:33
