Go to Post And remember, it's the fall semester. So FIRST isn't an excuse for a failing grade (not that it's ever an excuse)! - Billfred [more]
Unread 18-02-2008, 22:23
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
145 is D-O-N-E
It is such a relief to be done. Our bumpers are also done, they are where PINK (ewwwwwwww). Now they are black.
Can't wait for the Finger Lake Regionals. On saturday we broke a few things like the part that connects the flippers to the pneumatics, so we made them from steel. The lift had a few probs and we fixed them also. It's a little hard to turn, but we font that when we are moving it turns A LOT better.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 19-02-2008, 14:23
Jaybee1405
Posts: n/a
Re: 145 is D-O-N-E
Looks great. Are you within 80" at all times?
See you at FLR.
Unread 19-02-2008, 14:26
That guy
AKA: Dennis
Re: 145 is D-O-N-E
should be................ i really hope so.
Unread 19-02-2008, 15:19
BK Lounge's Avatar
BK Lounge BK Lounge is offline
Brian Kyte
AKA: BK Lounge
FRC #1591 (Greece Gladiators)
Team Role: Driver
BK Lounge is an unknown quantity at this point
Send a message via AIM to BK Lounge
Re: 145 is D-O-N-E
i cant wait for the finger lakes regional. are robot can herd, knock of ball, and hurdle. i guess will see u there. oh and ur robot looks pretty cool. does it hurdle?
nuts hold the world together, the world holds us, i hope we didnt forget to tighten them nuts
Unread 19-02-2008, 15:29
That guy
AKA: Dennis
Re: 145 is D-O-N-E
does everything, knock off in hybrid mode, hurdle, herd the ball, and place at the end.
Unread 19-02-2008, 16:26
pafwl pafwl is offline
Franciose
AKA: Frank Larkin
FRC #0272 (Cyber Crusaders)
pafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud ofpafwl has much to be proud of
Re: 145 is D-O-N-E
Looks pretty sweet. What are those little suction cup things are what ever they are for? Some kind of stabalization when hurdling. Se you at Finger Lakes.
TEAM #272 Lansdale Catholic Cyber Crusaders
Unread 19-02-2008, 16:31
That guy
AKA: Dennis
Re: 145 is D-O-N-E
suction cups???? Do you mean the flaps on the top? Those are to give up more area to his the ball with when we hurdle. Also they make it so the ball shoots off the one side if we hit it right.
Unread 19-02-2008, 17:20
Franciose
AKA: Frank Larkin
Re: 145 is D-O-N-E
no not those. there looks like there are two arms that come out on the bottom. looks like a couple of 3/4 inch pistons are hooked up to them letting them come in and out of the robot and two more to push it up and down. thought it was some sort of stabalization thing or something.
Unread 19-02-2008, 17:22
That guy
AKA: Dennis
Re: 145 is D-O-N-E
Ah they are used to help herd the ball around. They are kinda cool and could take someone leg off if you hit someone with them.
Unread 22-02-2008, 12:01
That guy
AKA: Dennis
Re: 145 is D-O-N-E
*bump*
Unread 23-02-2008, 00:15
Jon Ahmann's Avatar
Jon Ahmann Jon Ahmann is offline
FRC #2073 (Eagle Force)
Team Role: Driver
Jon Ahmann is an unknown quantity at this point
Re: 145 is D-O-N-E
Where did you get that pneumaic tubing? We have been trying to figure out the best way to run our tubing up our lift, and self-coiling seems that it would be the best way.
Unread 23-02-2008, 00:17
That guy
AKA: Dennis
Re: 145 is D-O-N-E
We coiled it our selfs, all you need is a large heat shrink gun and a PVC pipe.
Unread 23-02-2008, 00:22
Jon Ahmann's Avatar
Team Role: Driver
Re: 145 is D-O-N-E
Does that seem to work well, or does it get caught up in stuff?
Unread 23-02-2008, 00:27
That guy
AKA: Dennis
Re: 145 is D-O-N-E
It works well imo.
Unread 23-02-2008, 00:42
Jaybee1405
Posts: n/a
Re: 145 is D-O-N-E
If you're using square or round stock for your arm you can run the tubing through it.
Or you can use the ever-versatile zip ties.
145 is almost done DarkFlame145 Robot Showcase 6 11-02-2008 20:20
145 + Glue =awesome? DarkFlame145 Robot Showcase 32 30-01-2008 20:57
TRX 145 Xmas party DarkFlame145 Chit-Chat 1 11-01-2008 10:39
CD's Unofficial Caption Contest #145 Billfred Games/Trivia 31 22-04-2007 20:45
To T-REX Team 145 & TIGERTRONS Team 222 purpledaisy Chit-Chat 0 13-04-2003 22:06
