Go to Post One of the many unwritten laws of engineering failure is that the problem will occur in the most inopportune time. - Dave Scheck [more]
Unread 19-02-2008, 18:27
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Mass renaming of all parts in an assembly?
The rules state we need to have our team number in all our part file names. For example team_0342_XXXXXXXX.
The problem is we found out about it after we created 500+ parts.
Is there an efficient way to rename all our parts (adding the "team_0342" prefix) without causing a chain-reaction of broken links in the assemblies?
Unread 19-02-2008, 18:36
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Mass renaming of all parts in an assembly?
I don't think there is. My suggestion would be to break the assembly down into parts so that if you have 10 people, each only need to rename and assemble 50 parts. Then assemble them all into 1 assembly. I know that is still a lot of work. Hopefully, someone else will post an easier method, but I have learned that Inventor can be really disagreeable about file names.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 19-02-2008, 21:44
grim's Avatar
grim grim is offline
Inventor Guru
AKA: Todd
FRC #0549 (Devil Dawgs)
grim is on a distinguished road
There is no "bulk" rename method. You are correct in that renaming the filenames will "break" the links.
There is copy design functionality that will allow renaming of parts using a prefix, however that is only available if you are using Autodesk Vault to store your files.
My suggestion would be to use Design Assistant (Start Menu/Programs/Autodesk/Autodesk Inventor 2008/Design Assistant 2008).
"Does fuzzy logic create lint?"
Unread 21-02-2008, 11:16
Logan's Avatar
Logan Logan is offline
Inventor Zombie
FRC #0103 (Cybersonics)
Logan is on a distinguished road
You could import your final assembly into a 2D drawing and when it shows the i-properties names in the bottum right (if you set it up that way) you can rename them there and it will rename the part, and its i-properties will change.
Logan's Avatar
Inventor Zombie
Wait, does anyone know if its all parts or just the ones your team manufactured?
Unread 21-02-2008, 14:53
krankin krankin is offline
FRC #1164 (Project NEO)
krankin is an unknown quantity at this point
are you supposed to name every part that way or just the file that all of the individual parts are in.
Unread 24-02-2008, 11:17
grim's Avatar
Inventor Guru
AKA: Todd
Kevin I believe I have the solution for you. I was digging around in the user tools in the SDK directory in Inventor. There is a utility called copy design located here: C:\Program Files\Autodesk\Inventor 2008\SDK\Tools\Users\CopyDesign
Read the readme file and see if this fits the bill. It looks like it will rename with a prefix while maintaining links.
Unread 25-02-2008, 13:47
AKA: Kevin Thorp
Thanks Grim & everybody. I'll give your suggestion(s) a try.
Is everyone else including their team number in all their file names? The rules seem pretty clear. I'd hate to be disqualified on a technicality.
Unread 25-02-2008, 16:04
as I interpret the rules you only need to prefix the top level folders, JPEG, DWF, and your main assembly file "team_XXXX" leaving the assembly data alone under the top level folders.
I'm not certain about this and it would probibally be better to play it safe unless some one can clarify exactly how Autodesk/FIRSTbase wants the files.
Unread 25-02-2008, 16:39
Brandon Holley's Avatar
Theres no easy "find" --> "replace all"...however you can use the design assistant to make your life a lot easier.
Right click the main assembly out of a windows explorer box, and go to design assistant, you can then right click each part of the assembly, and click rename....you can change the name and the assembly will still kno which part to find.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 25-02-2008, 17:05
AKA: Kevin Thorp
Requirements copied from the Autodesk rules (I added the boldface):
A set of drawings (.idw or .dwf) which document the basic dimensions of the design
The assembly data for your robot (.iam and .ipt) --- parts and assemblies. All of the above files should be named using your team number, for instance “team_0123.jpg.” or “team_0123.dwf.”
Unread 15-03-2008, 16:16
dadstillsurfs dadstillsurfs is offline
I just designed it.. YOU build it!
no team (SFN)
dadstillsurfs is an unknown quantity at this point
I'm fairly new to Inventor, but our company is capable of "copying" projects by using a utility call "Pack and Go" to retain part / assembly relationships.
Must all parts of Robot be done? iwashere1990 General Forum 15 11-02-2008 14:04
Renaming the 2008 game... Leav Chit-Chat 2 09-01-2008 18:23
Renaming the FIRST Robotics Competition patrickrd General Forum 23 21-03-2003 00:03
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
Our Small Parts Experience, to all TEAMS Anton Abaya General Forum 29 04-02-2002 15:52
