Go to Post You are certainly welcome to demonstrate your geekiness on a regular basis! :) - Cynette [more]
Unread 02-19-2008, 07:46 PM
flamefixed flamefixed is offline
FRC #0219 (Team Impact)
flamefixed is on a distinguished road
Re: FRC488 - team xbot presents X8: The Ocho
first off, i do hope great minds think alike! haha. heres why -
we are sporting a lift, leaning backwards to keep the mass of the ball central over the bot, cascade style belting, driven up AND down with two cims by an entirely fabricated gearbox and a combination of delrin and 8020 rollers and t slots. (though are entire "guillotine" we call it, is made from 8020 stock.
many similarities. puts my teams mind at ease about our design more
looks incredible. best of luck to you!
Unread 02-19-2008, 07:55 PM
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
What's the overall length of your robot? We apparently made our base too long to implement an arm correctly.
Otherwise, awesome job! Good luck at your competition.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 02-20-2008, 03:01 AM
ladkahaidesi's Avatar
ladkahaidesi ladkahaidesi is offline
AKA: Amit
FRC #0488 (xbot)
ladkahaidesi is an unknown quantity at this point
Cool Re: FRC488 - team xbot presents X8: The Ocho
WHAT TIME IS IT?!?!?!?!?
Unread 02-21-2008, 02:00 AM
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
488!!! Many fond memories at Silicon Valley last year, and hopefully we'll see you again in Atlanta!
Beautiful robot. I like the tipping back, which I haven't seen yet this year. I only have one item to point out. How are you on other robots knocking into Ocho, either tipwise or possibly knocking the ball out?
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 02-21-2008, 02:03 AM
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Points from the last two posts appear to be clearly addressed in the robot stats that were posted
Originally Posted by M. Krass
# Remains upright until tipped to approximately 60* off horizontal in all directions -- with ball and elevator extended to maximum height.
# Physically incapable of violating <R16>
Unread 02-20-2008, 07:37 AM
MasterChief 573's Avatar
MasterChief 573 MasterChief 573 is offline
The Juggernaut
AKA: David McDonald
FRC #0573 (Mech Warriors)
MasterChief 573 is just really niceMasterChief 573 is just really niceMasterChief 573 is just really niceMasterChief 573 is just really nice
Send a message via MSN to MasterChief 573
GIVE IT UP FOR DELRIN!!! Thats the material we used to build our cams that manipulate our fork while being lifted.
2007 Great Lakes Regional Champs!
2007 Great Lakes Regional #2 Seed
2007 Boilermaker Regional Quarterfinalist
2007 21-8-1 Record
Unread 02-20-2008, 03:17 PM
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The robot is about 78" long with the forks and inclinator in their lowest position.
A significant percentage of our robot is plastic, with much of that being delrin.
  • Our omniwheels are largely delrin, as are all three encoder mounts.
  • Bearing blocks in the drivetrain are a mixture of delrin and polyethylene.
  • Pulleys on the inclinator are each a combination of delrin, ABS and polycarbonate, while the winch drum is made from polycarbonate, delrin and polyethylene.
  • Ball manipulator gussets are all polycarbonate, while it has polycarbonate ball stops and polyethylene skids.
  • Electronics are mounted to ABS
  • Dewalt XRP pinion is mounted to CIM shaft with delrin
  • Spacers everywhere are delrin
  • Linear slides on inclinator are polyethylene, rollers are nylon.
  • Pneumatics are mounted polycarbonate, tubing take up reel is polycarbonate, ABS and delrin.
  • IR board is delrin and acrylic.
...that's off the top of my head. There're probably many other things I'm forgetting. We love plastic.
--Madison--
...down at the Ozdust!
Unread 02-21-2008, 12:06 AM
octothorpe's Avatar
octothorpe octothorpe is offline
AKA: Nick Felt
FRC #0766 (MA Bears)
octothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to beholdoctothorpe is a splendid one to behold
Very nice robot – a truly elegant job on the paneling, and a design that's clearly very capable at the game. Sounds like a phenomenal sensor package too, I wish we had that kind of intelligence on our robot. My only qualm is at your mention of redundant cabling... because our elevator lacks it. Not that we had room for the extra weight anyway . Good luck and 766 will hope to see you at Championships!
Unread 02-21-2008, 01:37 AM
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Will that fit inside the 80" cylinder?
Sincere thanks and congratulations from 'team xbot' Madison Thanks and/or Congrats 1 04-16-2007 09:45 PM
Team 233 presents The FIRST Robot Rock Opera: The Factory Gabe Salas Jr. General Forum 7 03-04-2007 08:07 PM
Team 233 presents The FIRST Robot Rock Opera: The Audition Gabe Salas Jr. General Forum 15 02-26-2007 07:32 PM
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 11-22-2006 09:21 AM
pic: Team 294 proudly presents The Predator Daniel Brim Extra Discussion 2 02-22-2005 02:43 AM
