Go to Post If I had a dollar for every time I thought we'd get a legitimate hint....Well, I might have a few dollars... - Andrew Blair [more]
Unread 19-02-2008, 17:36
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Ideas for wire placement
Name:	Lift Picture.jpg
We are afraid that the wires will get snagged, cut, tangled, et cetera.
Any ideas on how to do the wiring to prevent these problems.
Unread 19-02-2008, 17:52
Re: Ideas for wire placement
Do you guys have the cable chain (or whatever it's called) from the KOP, Igus bag? If so, that might work. Or wrap all the wires together to make one cable. It shouldn't be too hard to do the latter, and the former is a specialized method.
Unread 19-02-2008, 17:55
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
How are you doing on weight? Options of varying weight impact include:
  • A hatch to cover your main electronics (leaving the 120A breaker button available for emergency reset and the controller lights visible).
  • Ty-wrap to group your cables and link them to non-moving parts of the structure.
  • Keep your cables as short as possible (while allowing for minimum bend radii and routing considerations)
  • Some form of conduit to enclose a wiring bundle and protect it from snags and abrasion. Useful types of this include the IGUS energy chain from the KOP and something we usually call "vaccum cleaner hose conduit").
Unread 19-02-2008, 18:00
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
We will look into (and for) those options. Currently we are at 100 lbs. Thanks for the replies thus far.
Unread 19-02-2008, 19:48
vhcook's Avatar
Reader of Things
AKA: Victoria
I didn't have a chance to look this up before but the hose-style conduit is apparently officially called wire loom. Here is one of the many sources. Tends to come in 100' increments (or more). It's basically a hose with a slit up the side. http://www.electriduct.com/wire-mana...l-purpose.html
Unread 19-02-2008, 19:52
Xena Xena is offline
Electronics Tech / Parent
FRC #0647 (Cyberwolf Corps)
Xena is an unknown quantity at this point
With the limit switches in several locations, creating a single "cable" has proved to be somewhat of a challenge. Part of the wiring is in the cable chain provided. A very flexable cable wrap may help for the rest. Thanks. ---Any other ideas?
Unread 19-02-2008, 20:19
DonRotolo's Avatar
Back to humble
FRC #0832
You need to learn the concept of "Wire Dress", that means to bring all the wires neatly together into a nice bundle. Look under the hood of any car for an example.
Lots and lots of wire ties, and some kid who is a neat freak will work.
Believe it or not, pipe cleaners make great wire dress items: Just wrap in a small spiral every few inches or so.
At the regional, look around for good ideas...
Don
Unread 19-02-2008, 23:15
Jesus,
You might try making a zig-zag run from one side of the robot to the other. Place the elevator section of your robot at it's highest point and set the length of your wiring from top to bottom. Then use a wire tie at the top and bottom of the run to hold your test wire in place. When you collapse the elevator you will see the wire try to fall in a zig-zag fashion. Using some elastic or surgical tubing, try to pull the wire to one side and/or the other as the elevator goes up and down. If the tubing is too strong, it may be slit along it's length to form narrow strips that are not as strong as the whole tube. use the tubing to keep the wires from getting caught by the moving parts of the elevator. If you have a small bundle of wiring, wire ties placed a few inches apart for the whole length will work to keep the wiring together. If the bundle is larger, you might want to use "split loom" tubing that can be found at Radio Shack, MCM or a local car stereo outlet.
Minimum Gauge Wire for Sensors? psquared89 Electrical 2 05-02-2006 15:26
New LED Lights this Year, spec for placement? Chris_Elston General Forum 12 16-02-2004 17:32
Wire Mesh for Ramp MechaJagEric General Forum 2 27-01-2003 18:49
Ideas for fundraising for 'special' teams? Amanda Morrison Fundraising 12 01-12-2002 14:31
Looking for aluminum wire archiver 2000 5 23-06-2002 23:48
