Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 19-02-2008, 19:58
pyxelz's Avatar
pyxelz pyxelz is offline
NathanParrish
FRC #0973 (Greyhound Revolutionary Robotics)
pyxelz will become famous soon enoughpyxelz will become famous soon enough
Talking 973 Completed Bot 2008 - ARMageddon
ARMageddon
Shown here still missing a few things: the front bumper, and some thin lexan panels that velchro on around the base.
Chassis:
- 6-wheel drive
- 2 CIMs per side
- 2-speed Super Shifters from AndyMark
- 7 fps low and 17 fps high
Arm and Grabber:
- single-joint arm
- knocks down ball
- hurdles
- places ball at end
- can grab ball while driving full speed (17 fps)
our arm lifting up a student. Max load is approx. 600 lbs.
Unread 19-02-2008, 20:00
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: 973 Completed Bot 2008 - ARMageddon
Lifting a student...?
What motor are you driving that arm with and with what ratio?
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 19-02-2008, 20:03
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
600lbs lifting ability!!!!!!!!!!!!!!! holy cow, the ball weights 7lbs
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 19-02-2008, 20:04
BK Lounge's Avatar
BK Lounge BK Lounge is offline
Brian Kyte
AKA: BK Lounge
FRC #1591 (Greece Gladiators)
Team Role: Driver
BK Lounge is an unknown quantity at this point
Send a message via AIM to BK Lounge
i believe there is a rule that says u can only drive 5 ft per sec. or was it 5 meters. idk.
a little overkill on the arm lift mechanism. thats greatwish we had sumtin that strong. we got a huge 2ft air piston.
nuts hold the world together, the world holds us, i hope we didnt forget to tighten them nuts
Unread 19-02-2008, 20:22
There isn't a speed limit on THIS track. Whoever told you there was doesn't know the rules. (That said, 5 m/s is the practical maximum of speed that is controllable.)
Ryan--2004 and 2006 both had rules like that. 2004:10 fps on whatever contacted the bar. 2006: 12 m/s launch velocity on a poof ball. No other speed limits that I know about.
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
There is no rule limiting how fast you go. I believe there was in the past (2005 if I remember right) That's pretty much one of the main points of the game... to go as fast as possible.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 19-02-2008, 20:27
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
All I can say is, with that kind of lifting capability there's endless possibilities for what you can do with it off-season.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 19-02-2008, 20:38
pyxelz's Avatar
NathanParrish
lol well, we had the weight, so we put on some extra motors. The arm is just that much easier to control because it is difficult to back-drive.
Let's go exist somewhere.
Unread 19-02-2008, 20:43
pyxelz's Avatar
NathanParrish
Yes, the plotting starts now...
The only problem is that the chain tensioner slides up the arm when too much force is applied - thus loosening the chain so it must be re-tightened.
Unread 20-02-2008, 20:05
AdamHeard's Avatar
Lead Mentor
Meh.... It happens, I was hoping the slotting in the gearbox mount would clamp well enough.... But, just too much load on that length of chain.
We'll work at the meeting tomorrow to plan a simple tensioner we can build on Thursday.
the gear reduction is rather hodgepodge. We had banebots fail due to shaft misalignment, so last minute we made a SUPER HODGEPODGE gearbox from AndyMark. It required just one plate to be cut, and one shaft modified. It is the 2 FPs and the RS550 motors going into AM planetaries, from there they drive (with 14T pinions for the FP, and 12T for the 550) the 50T from the stackerbox, that is the input using the 14T from the stackerbox to an AM toughbox with both stages. The output shaft is a modified SS long wheel shaft because the stock wasn't long enough.
The sprocket reduction is a 14:36 in #25, then a 10:60 in #35. This puts the overall reduction on the arm at ~ 2580:1 from the FP motor.
If you're at SVR or Vegas, check the arm gearbox out, it certainly is cool looking.
pic: Completed RCCR Vex Bot Dylan Gramlich Extra Discussion 11 20-11-2006 15:21
1596's completed bot Skolar Robot Showcase 5 25-02-2006 09:12
30's Completed Bot pics RobDeCotiis Robot Showcase 11 08-04-2003 16:07
Team 30's bot-- nearly completed RobDeCotiis Robot Showcase 9 21-02-2003 09:32
