Go to Post I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. - Joe Johnson [more]
Unread 19-02-2008, 18:14
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Help a rookie please
Hey, i've never used pneumatics and now i have some problems with it, beeing my first time.
What i need:
Have a cylinder that can move my gripper to 3 different positions.
Poisiton A: Grab the Ball
Position B: lift the ball up to the arm (so we can get in the 80'' length limit while lifting the ball.
Positiion C: Gripper touches the arm, only needed in start of the match in order to get in the initial sizes of the game.
Is there any way i can easily do this?
Please remember you are speaking to a pneumatic noob, so i will probably need both an explanation on how to mechanicly do it and how to program it.
i've read some threads that say that i should connect 2 selenoids together, but i did not really understand how i am going to control it.
PS, the cylinder there will basicly need to make te following move:
start of match from poisition C to A, and the rest of the match just switch between positions A and B, mechanicly the order of the positions is C-B-A.
Thanks =]
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 19-02-2008, 18:19
Re: Help a rookie please
Easiest way: 2 cylinders, end-to-end.
Second easiest way: 2 solenoids. One is connected to the other's exhaust port. This will be a "soft" middle position.
I'll let someone else explain how to program it. Partly because I'm not exactly sure how.
Unread 19-02-2008, 20:04
DonRotolo's Avatar
Back to humble
FRC #0832
See THIS Thread. There is no need for two solenoid valves, ever, to make a piston stop mid-stroke. This is done all the time in industry, and of course there is a simple solution.
Just keep in mind that air is compressible. That means, if the load on your piston changes, it will move from that mid-point position.
Don
Rookie Team 2582 with a problem... Please Help RoboGeek99 General Forum 4 18-01-2008 00:57
Metal Muscle Team 1506 Rookie Website - Please take a look! Alexander McGee Website Design/Showcase 19 20-01-2005 11:48
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
please help us, pretty please :) archiver 2001 0 24-06-2002 03:13
