Go to Post resist the hive: As goofy as this may sound, wires do take up weight, several pounds of it. - Rickertsen2 [more]
Unread 19-02-2008, 10:38
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
kit of parts tubing
was the tubing you got in the kit rated at 175 psi?
Unread 19-02-2008, 11:34
gam3fr3ak1 gam3fr3ak1 is offline
AKA: Chris
FRC #0435 (Robodogs)
Team Role: Driver
gam3fr3ak1 is an unknown quantity at this point
Re: kit of parts tubing
ours was, i posted something on the Q&A a few minutes a go, because another Q&A reply said something about 175 psi not meeting criteria, im not sure exactly what that criteria was...
Unread 19-02-2008, 11:40
REVving up for a new season
FRC #2848 (All-sparks)
[Public service announcement] regardless of the tubing rating that doesn't mean you should have anything 175psi on your robot. High side of the system 120psi max. Low side 60psi max. The tubing you got in the kit is fine for this application.[/PSA]
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-02-2008, 11:49
Rupnick's Avatar
I posted the question of heatreating to coil tubing and using the 175psi tubing we recived in the KOP but, first replyed that 175psi did not fit the criteia of <R87>
Unread 19-02-2008, 12:04
Racer26 Racer26 is offline
If it was in the KOP, you can be 99.99999% sure its legal to use.... at least, for its intended purpose anyway.
Unread 19-02-2008, 22:39
Rupnick's Avatar
I know that but in a Q&A reply we got it said 175 psi tubing does not fit the criteia of <R87>
Unread 19-02-2008, 23:27
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
I dont think its at all possible to have a KOP item thats illegal .
As far as pneumatic tubing goes my teams colors are red, white and black . Instead of using this years ORANGE TUBING , i nabbed some of our old BLACK kop tubing
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 19-02-2008, 23:52
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
I believe that the criteria for tubing would be this, not going over 120 psi in general. If your psi is going to be 175, then you have something else you need to fix, not the tubing. Do you have safety switches installed?
On second thought, if this is scrap tubing needed for a project outside of competition, then I really have no idea.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 19-02-2008, 23:57
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
For reference, this appears to be the Q&A in question:
http://forums.usfirst.org/showthread.php?t=8802
It sounds like either you or somebody on the GDC is a little confused about what pressure the tubing in the kit is rated for.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 20-02-2008, 00:02
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
No... Wait.
We are saying that the tubing that come in this years KOP is illegal due to the this post on the Q&A.
No. Any additional tubing used on the Robot must satisfy Rule <R87> and be functionally identical to the tubing provided in the Kit Of Parts. 175 psi tubing would not satisfy this criteria. Furthermore, heat treating the tubing will alter the physical characteristics of the tubing, and again make it dissimilar from the tubing provided in the Kit. Coiled tubing rated for 125psi that is functionally identical to the tubing provided in the Kit Of Parts is available from several commercial sources.
The tubing that came in the this year KOP is rated at 175psi, we are not saying that we are running at that.
So the question is can we use it?
edit: Sorry slow typer.
We posted that with this year KOP tubing in hand and read the rating off of it.
Unread 20-02-2008, 00:33
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Then it's the GDC that is confused. While the answer about coiling your own tubing should still stand, the rest of that Q&A needs to be revised. I would recommend submitting a follow-up question so they can clarify.
_
Unread 20-02-2008, 09:14
AKA: Chris
Team Role: Driver
I posted a clarification question on the Q&A yesterday when I saw that Q&A post. So check back on the pneumatics Q&A forum soon and a clarification should be there.
I just looked at the Q&A post again, and they corrected it. They removed the sentance that said that the "175 psi tubing does not meet the criteria." But my post should still be clarified soon...I hope.
Unread 20-02-2008, 13:23
DB_UPS's Avatar
AKA: Ryan Quinlan
There i guess its ok to use still?
Unread 20-02-2008, 18:20
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Check the follow-on Q&A answer.
-dave
Unread 02-03-2008, 12:29
HotWings HotWings is offline
AKA: Jon
FRC #0548 (Robostangs)
Team Role: Webmaster
HotWings is on a distinguished road
if you read freelin-wades's rating of 175, i bet you can pump that up to around 250ish... just for safety they have to crank it down.
Kit of Parts Andrew Y. Inventor 18 22-01-2008 15:51
2004 Kit of Parts Matthew_H Electrical 3 06-01-2004 20:47
Parts dropped from the 2003 Kit of Parts? D.J. Fluck Rumor Mill 38 03-01-2003 19:29
Titanium Tubing (Small Parts Catalog) archiver 2001 5 23-06-2002 23:25
does small parts sell rectangular aluminum tubing mnkysp6353 General Forum 2 09-12-2001 01:28
