Go to Post We are here to educate, inspire, and mentor not only the students, but teams who need guidance, whether they know it or not. - Andy Baker [more]
Unread 20-02-2008, 01:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by sumadin View Post
I've been running into an odd problem with encoders.
Encoder 1 works perfectly fine during the teleop period, but does not give me anything during the autonomous one. Encoder 2 works in both teleop and autonomous. The initialization functions is called during both the autonomous and disabled initialization routines.
I am running your latest code build, as far I as know, with MPLAB 8 and C18 3.10. While the robot is shipped already, I'd love to hear if you have any suggestions for what to try.
It could be that the encoder is working, and is giving the correct signals, but is always printing a zero in my debug statement, and the code that is executing makes me believe that it is seeing a zero (as the count). But when I print out the count in the teleop mode, I get numbers that make sense.
A common reason for this is the wrong printf() format parameter is used. Use %ld instead of %d.
-Kevin
Kevin Watson
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
