Re: ROBOT C and the LabVIEW Dashboard
The pressure sensor from the KOP is a digital input.
AS for sending data to the OI the data you need to send is called a "User Byte" |
There are 6 user bytes that get sent back to the OI, along with the PWM information for PWM outputs 1-16. A few other things get sent back as well; take a look at the packet spec to get all the details.
To set a user byte, you do something like Code:
User_Byte_1 = 243; This LabVIEW code is a great place to start: http://www.chiefdelphi.com/forums/sh...71&postcount=8 |
| Example LabVIEW Apps - Dashboard, CMUcam2 and Motors | DanDon | LabView and Data Acquisition | 3 | 29-01-2009 22:13 |
| Example LabVIEW Apps - Dashboard, CMUcam2 and Motors | Russ Beavis | National Instruments LabVIEW and Data Acquisition | 9 | 21-01-2007 17:19 |
| Where can i download the LabView Dashboard? | Zak698 | NI LabVIEW | 2 | 11-01-2007 15:57 |
| Labview Dashboard and updated IFI dashboard spec | Joe Ross | LabView and Data Acquisition | 1 | 04-04-2006 02:04 |
| Labview dashboard and multiple variables | Joe Ross | LabView and Data Acquisition | 2 | 15-03-2006 21:55 |
